Question about Canon Office Equipment & Supplies
How do I clear error E100 on my Canon GP215 photocopier? The paper keeps on jamming continuously.
    Sergeant:
  • 199 Answers
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
The BD signal is not generated during image formation
because this error is related to LASER UNIT & BD UNIT we suggese try to repairing with help of a technician, don't self.
Thank's for using FIXYA
Posted on Jun 22, 2009
Am using canon gp215 i got error E064 what does it mean dont have tech manual
Posted on Aug 26, 2009
How to clear e000067 for canon irc2880i copier
Are you looking for Canon printer support number to sort out issue related with your printing machine? We also provide the Canon Printer customer Support, Canon Pixma Support Number, software installation, software upgrade, cartridge jam, paper jam issues and much more. Canon Pixma Printer Support
Jan 18, 2016 | Canon Office Equipment & Supplies
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
Nov 28, 2013 | Office Equipment & Supplies
Error E100 on Canon iR1024A
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Jan 31, 2013 | Office Equipment & Supplies
Odds are you will need to replace the fixing unit. The error code deal with the fixing unit not heating up to the correct temp.
May 22, 2012 | Canon Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Consant paper Jam - Canon 1600 photocopier
Try to clean the rubber parts. Probably these are filled with paper dust.
Jul 22, 2009 | Canon ImageRunner 1600 Copier
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Systems Error E100
ERROR E100 is results when DRUM UNIT is not sitted properly , please check it is engaged with toner ( developing assy).
Oct 02, 2008 | Canon Image Runner 1630 Copier Copier
583 people viewed this question
old marine
old marine
