Question about Gateway Computers & Internet
Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
Hello I hope you can help.
Gateway part number 400532 with E139761 stamped on top of circuit board. Need to identify case to motherboard connectors on motherboard. This is necessary because old powersuply unit as died, so I am moving all components into a new case that has a new power supply. Failed power supply unit is Newton 200W/1.7A model NPS-200PB-96 D REV:00) -Inrush current limiter has blown.
The Gateway board has three memory slots on it but again I do not know if I can increase memory or the maximum memory it will take.
Hence requirement to obtain motherboard manual/specs.
Many Thanks
C.D. Murray
  • 14 Answers
The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • Posted on Jun 21, 2009
    I just bought an old intel E139761 mother board and i didn't get any info on the jumper setup. can you help me ? i need a diagram.
    Looks like this is an Intel board PD440, (PD440FX manual is here) (SE440BX is here). Check both of these manuals to determine which is your motherboard. This will give you jumper info and anything else you need.
    Apr 22, 2011 | Gateway (4000440) Motherboard
    Hi dear can this motherboard suport intel pIII
    Here are the specs. to this motherboard Product Details Intel 810E Chipset, Socket 370, Compatible Processors: Intel Pentium III Specifications Key Features Chipset Intel 810E Compatible Processors Intel Pentium III Processor Max supported CPUs qty 1 Socket Type Socket 370 Memory Number of Memory Slots 2 x DIMMs Audio / Video Video Out Ports 15 Pin D-Sub VGA port x 1 Other Features Package Qty 1 Chassis Type Desktopso to your queston... Yes it supports Intel PIII have fun >.<
    Feb 25, 2010 | Dell (002TR) Motherboard
    PC Chips M756LMRT+ PII/III/Celeron Slot1/Skt370 mATX MB Motherboard, put this into new tower and having trouble with connecting the PW SW,HDD LED, PW LED and Reset SW back to board in the correct position...
    I have the same problem! The PW SW, and Reset SW can go either way round. The LED leads do need to be correctly placed. If there has been any doubt in the past I have tried each way until one way works - this has never caused me any problems. One tip is that usually the marking on the connectors all face the same way.
    Oct 29, 2009 | PC Chips M756LMRT+ PII/III/Celeron...
    What is the Maximum RAM that can be attached to Intel Pentium III with Motherboard "Gateway Tabor3 CopperMine WS440BX"...?
    I had a look on the web and came across an answer. According to he site the WS440BX can only handle 384MB.
    Hope this helps!
    Please rate this..
    Cheers
    Sep 27, 2009 | Gateway Tabor 3 (4000532) Motherboard
    Changing FSB & Voltages
    Hi there.
    You can change the front side bus in the bios if the bios supports it, if it does be very careful not to overclock the processor to much as you can cause damage to the motherboard and blow the processor up, also bear in mind that cooling is very important when it comes to overclocking.
    Good luck and thanks for using FixYa!!
    May 13, 2009 | Gateway Tabor 3 (4000532) Motherboard
    Need manual
    go to the intel web site It will be there,watch out when you download it,it might be in ten different languages,and will waste ink for nothing
    Apr 09, 2009 | Intel Computers & Internet
    Cannot use intel pentium processor
    you can only use socket 370 (Intel Celeron/Intel Pentium III) processors on that motherboard. Your maximum cpu speed is set by the bios.
    Feb 19, 2009 | Gateway PGA370 E139761 DIMM Motherboard...
    Intel E139761 or AA 732604 Motherboard wiring diagram
    http://www.cs.unc.edu/~jeffay/dirt/FAQ/DELL410_ServiceManual.pdf
    Seems you have a Dell computer. Is this manual the right one?
    Feb 06, 2009 | Intel AAVID Pentium III Dual Cooling Fan -...
    Motherboard upgrade
    That computer uses a proprietary motherboard. Only that one or one from the same Gateway family will fit, and the power supply from an old PIII will not work with the newer systems. Don't waste your cash.
    Cheers
    Jan 04, 2009 | Computers & Internet
    Need user manual for E139761 intel motherboard.
    Hello ganeshfulare;
    I have your answer(I hope:). Using j10d10, place wires accordingly;
    red goes to 1, black goes to 3(for power led)
    green goes to 2, orange goes to 4, black goes to 13(for HDD led)
    blue goes to 6, white goes to 5(for power switch).
    I guess the colors may differ slightly, but thats how it is on mine and it works properly. I was wondering if you(or anyone out there knows what the other IDE port is for(next to the dimm slot)? I am in the process of putting this old thing back together and was just curious.
    Jul 05, 2008 | Intel (SR1400SYSNA) Server
    Computers & Internet Logo
    298 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
