Question about Remington R-9190 Electric Shaver
How do I open the Remington 9190 Electric Shaver to replace the battery?
  • 3 Answers
Remove the Two ( 2 ) Phillips Head screws on the Back side of the
R 9190 shaver near the Electrical Plug .
Pry off the Gray Rubber cover that those two ( 2 ) now removed screws went thru.
Now remove the Two ( 2 ) exposed screws up near the " Trimmer Switch "
Note: If you Popped off the " Trimmer Switch " during your efforts - DON'T WORRY . It will simply pop back in place when you are finished with your repairs.
Posted on Aug 17, 2010
Need a replacement battery for remington ES1000 electric shaver and blades
Unfortunately, blades for this model were discontinued several years ago by the manufacturer and are now impossible to find now.
Batteries can be purchased from shaveroutlet.com. You will need two. See link below
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
Sep 22, 2011 | Remington ES-1000 Electric Shaver
How do I find where the battery is located?
To open the shaver and access the batteries, you must start by gently prying off the rubberized grip on the front. Once removed, you can access and remove two screws at the bottom. Under the cutters is a metal plate/clip. Remove this clip and the front of shaver can be removed and batteries accessed,
You will find replacement batteries at shaveroutlet.com. See link below. You will need two
If this job is out of your capabilities, you might want to consider the replacement part linked below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms2370-lower-unit-p-208.html
Jan 10, 2011 | Remington MS2-200 Electric Shaver
How to open remington ms3 1700 electric shaver to change battery and battery type??
Your shaver model is not designed to replace the batteries. To open it, you have to remove the side grips on oscillator housing which are glued on. Disassembling it will cause it to be all marred up.
shaveroutlet.com has an easy and inexpensive solution. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms31000-lower-unit-p-567.html
Oct 04, 2010 | Health & Beauty
R-9190 Electric Shaver: The razor is used 20 seconds a day and used to go ...
The problem is almost certainly the batteries. You can access the batteries by removing the screws on the back and taking off the back cover. You will find batteries at shaveroutlet.com. You will need two batteries. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
May 05, 2010 | Remington R-9190 Electric Shaver
Shaver won't hold a charge, can battery be replaced?
Yes, you can replace the rechargeable batteries in your shaver with a few basic skills. If you can disasseble the shell case and have access to a soldering iron, you can remove the old faulty batteries and reinstall the replacement ones. Not only will you save a ton of money, but you'll have your trusty shaver running like new quickly!
Here's a link to Electric Shaver Service's battery page that has your battery listed (R-9000 series) for around $15.00 plus S&H.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
I've done this on my own razor twice in the past 10-15 years and it's still less expensive than buying a new razor, since I really like the shave I get with mine.
Hope you find this Very Helpful and best regards!
Aug 16, 2009 | Remington R-9190 Electric Shaver
How to open for battery replacement
Found this link that may help you out. Seems like they are made to be used then tossed out. What a waste. Anyway the battery replacement issue is a common problem... http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
May 25, 2009 | Remington R-9190 Electric Shaver
I have charged it for more than 24 hrs and the shaver is hot, yet it does not turn on when i press the button, should i just return and replace it?!?
Same thing happened to my Braun trimmer. The internal batteries only have a certain rechargeable lifespan and then need to be replaced.
Can you take it apart and see what the battery voltage is and see what the ma (milliamp) rating is? Also battery size (length, width & diameter)?
With that information, we can probbaly find you a replacement battery. I did for my Braun and its as good as new now.
- Jim
Feb 09, 2008 | Remington R-9190 Electric Shaver
Remington R-9190 Electric Shaver Logo
785 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
