Question about Black & Decker Leaf Hog Blower Bv4000
Switch fell apart on inside when I opened the case
My bobber case fell apart, how do I fix?
It will probably be better to just purchase a new replacement bobbin case. Bobbin cases do wear out and since yours fell apart, it may be suffering from use and age. There is also the hassle of trying to get the bobbin tension correct. New bobbin cases generally do not cost that much and you will know that it is factory set and ready to go in your machine.
Jul 19, 2017 | Sewing Machines
Sunroof wont open no power were are my fuses
I'm not sure what's going on with your circuit, I have also a same problem. when I replaced the switch the sunroof worked. I ended up taking the old switch apart and when i poped off the cover some of the plastics inside were broken and wedged in places they shouldn't have been probably causing a short. I am not real sure because when I opened the switch it pretty much fell apart. Liquid Roof Coatings Application and Uses BuyLiquidRoof
Jan 13, 2014 | 2003 Hummer H2
Can some tell me if they have a picture of the inside on the switch my fell apart need put back together?
If you click HERE you will be taken to a web page of part numbers and the exploded view diagram's of the area of the washer the parts is located in.
Dec 15, 2011 | Roper RAS8445KQ Top Load Washer
Took the nozzle apart on my hoover steam cleaner upholstery attachment because it was leaking, fell apart andf now I cannot get the switch in the correct place or for that matter cannot get it all back in...
whats the exact model number of your vacuum unit and exactly which switch fell apart, the switch on Handel or its any other switch.------- Where exactly this switch is located, so the exact fitting / installing procedure can be provided.------- Keep updated, thanks.Helpmech.
Aug 18, 2011 | Vacuums
Pt 3406107 fell apart. I need to know how it is wired to put it back together. It is the door switch that cuts off the dryer power when the door is opened. There is a small spring and a free standing...
if it fell apart Just get a new one and use the connector supplied with it ,, Once they give way they possess a danger better safe than sorry and the part isn't that expensive, heres the part for 16.00 and change !! http://www.partselect.com/PS346704-Whirlpool-3406107-Door-Switch.htm?inventory=346704&SourceCode=6
May 24, 2011 | Maytag Dryers
Pump fell apart - inner piece fell out
On these newer pumps, the plastic piston comes apart, and to fix it a new part is in order. Without looking at it, I think that is what might have happened. Bicycle pumps are almost throw-away items these days. In the old days you could buy all sorts of pump parts, but not anymore. Good luck
Jan 05, 2010 | Cycling
Key ignition will not turn. I have tried moving the steering wheel.
the key switch is probably bad it fell apart inside.you may have to cut the two bolts off to remove the old switch,the new one comes with bolts.At the bottom of the wire you can pull it apart.
Aug 17, 2009 | 2005 Honda Civic
Verizion LGvx5400 fell in toilet
  The main effect of water is on the motherboard of the cellphone.
In case, it has not affected the working of cellphone/motherboard inside that, you can keep the cell in dry temperature for  few hours, you can use a dryer or you can open the lcd/screen panel and you can also use soft cotton to keep it dry.
Thanks for using Fixya.
Apr 23, 2009 | Cell Phones
Need to take apart DX6490
As you told that , the camera fell on sand, Its highly unlikely the sand would inside the camera, because the camera case is air tight. There could be more to the camera problem then just sand.
Refer to the following link from the product manual
http://www.kodak.com/global/en/service/publications/urg00167toc.jhtml?chapsec=urg00167c10s1&pq-path=1600
Thanks
Proton
Jul 16, 2008 | Kodak EasyShare DX6490 Digital Camera
Black & Decker Leaf Hog Blower Bv4000 Logo
98 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
