Question about Bowflex Treadmill Series 7
I get an L5 Err message and the treadmill will not move.
While it was in operation (just before dying), there was a burning smell of plastic.  If anyone has had this problem, please let me know the resolution.
Jeff
  • jkassels Jun 21, 2009
    This is for a Nautilus NTR 800
    Problem Solver:
  • 5 Answers
Not a chance this is speed sensor related, the probability that a magnetic pickup is "fried" is near zero. This is a classic over current problem caused by lack of lubrication / old belt and deck. Something on the motor controller melted (hence the smell of burning plastic). This will need to be replaced most likely although these units contain a slow blow ceramic fuse that may have tripped first. At any rate the unit should be tested for current draw before being put into regular use again.
Posted on Mar 15, 2010
    Sniper:
  • 75 Answers
Sounds to me like your speed sensor fried itself. The speed sensor is on the pulley that turns the belt. If you're under warranty them give bowflex a call. If not under warranty you can still call and order the part. Porbably about $20 for a new sensor.
(800) 952-7205 - Bowlfex Customer Support
Posted on Jun 22, 2009
HI our Bowflex series 3 treadmill is giving us a continued Err L5 code when trying to use our machine. We bought it used so do NOT have ant trouble shooting instructions. Any advice?
Hi There, L5 error should refer to the "LS" error which looks up to a speed problem. When you start the machine up, it boots fine and then when you press start or go is says err ls ? If the walking belt doesn't move at all when you try to start it, listen for a "Click" on that lower board when start is pressed..... If the walking belt moves for a second and then stops and the console says err ls, then you may have a speed sensor problem. These control boards are repaired by Jatinah Electronics who can be found with a google search. Good Luck!
Dec 13, 2016 | Bowflex Exercise & Fitness
I have a sports art 1180 treadmill that beeps err 7 how do i fix this thanx
ERR E-7 indicates that the DC incline motor and the variable resistor (VR) are not synchronized. Signal from the VR is not being received properly. Mechanical and/or electrical calibration is needed to reset this error message.
http://www.sportsartamerica.com/SAF/support/technicalsupport/techtips/Treadmills/DC_Incline_Calibration.pdf?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Jul 05, 2012 | Exercise & Fitness
There is bad smell from the motor
Dear Sir:
There can be 3 options: 1) Deck belt smell bad 2) Drive belt smell bad 3) Drive main motor winding burn. Test it and proceed according.
or Course you can do it by yourself or 2) call to service tech.
God bless you
May 22, 2012 | Exercise & Fitness
My bowflex treadclimber starts for abut 3sec then err L5 shows on the screen PLEASE HELP!
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Jan 22, 2011 | Bowflex Treadclimber
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
Candence 825, motor not driving belt, smells of burning
Hi Jill, have you found a solution yet as I seem to be getting a sililar error. Do you get a E02 message and a beep. Thanks Nicky
May 18, 2009 | Cadence Weslo 825 Treadmill Walking Belt
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
Err LS on Bowflex Treadmill
The machine needs to be re-callibrated. L5 error.
The instruction book doesn't mention calibration. be sure to not callibrate in metrics, however (there's no way to easily tell the difference - you have to ask) or you'll be strolling like a walk in the park at 5 "mph".
Thanks for using FixY - a FixYa rating is appreciated!!
Feb 21, 2009 | Bowflex Treadmill Series 7
Bowflex Treadmill Series 7 Logo
872 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
