Nov 04, 2007
- I treid not to get techincal on you but here goes....
Make sure
you disable or uninstall any PPPoE software such as WinPoet, Broadjump,
or Enternet 300 from your computer or you will not be able to connect
to the Internet. Do not disable until you´ve downloaded the firmware in
Step 1. Please make sure that your modem is not also a router. If it is
or you do not know, please contact your ISP and change the modem to
Bridge mode.
Note: In some areas, BellSouth and Verizon may not use PPPoE. If you receive a dynamic IP address, please
click here for setup instructions.
Step 1 Upgrade to the latest firmware.
Step 2 Take a paperclip and perform a hard reset. With unit on,
use a paperclip and hold down the reset button on the back of the unit
for 10 seconds. Release it and the router will recycle, the lights will
blink, and then stabilize.
Step 3 After the router stabilizes, open your web browser (Internet Explorer, Netscape, etc), enter
192.168.0.1 into the address window, and hit the
Enter key. When the password dialog box appears, enter the username
admin and leave the password blank. Click
OK.
If the password dialog box does not come up repeat
Step 2.
Note: Do not run Wizard.
Step 4 Click on the
WAN tab on left-hand side of the screen. Select
PPPoE.
Step 5 Select
Dynamic PPPoE (unless your ISP supplied you with a static IP address).
Step 6 For Earthlink users, under the username field enter
ELN/username@earthlink.net and your password, where username is your own username (some Earthlink users may not need the
ELN/ in front of username).
For SBC Global users, enter
username@sbcglobal.net.
For Ameritech users, enter
username@ameritech.net.
For BellSouth users, enter
username@bellsouth.net.**
For most other ISPs, enter
username.
Note: In some areas, BellSouth may not use PPPoE.
Ameritech users: If you cannot connect, try entering just the
username (without the @ameritech.com) and then put ameritech.net in the
Service Name box.
Step 7 Maximum Idle Time should be set to zero. Set
MTU to 1492, unless specified by your ISP, and set
Autoreconnect to
Enabled.
Note: If you experience problems
accessing certain websites and/or email issues, please set the MTU to a
lower number such as 1472, 1452, etc. Contact your ISP for more
information and the proper MTU setting for your connection.
Step 8 Click
Apply. When prompted, click
Continue. Once the screen refreshes, unplug the power to the D-Link router.
Step 9 Turn off your DSL modem for 2-3 minutes. Turn back on.
Once the modem has established a link to your ISP, plug the power back
into the D-Link router. Wait about 30 seconds and log back into the
router.
Step 10 Click on the
Status tab in the web configuration where you can view the device info. Under
WAN, click
Connect. Click
Continue
when prompted. You should now see that the device info will show an IP
address, verifying that the device has connected to a server and has
been assigned an IP address.
