Question about Garden
North Star Pressure washer Model 157370C Coupler Part broken between engine and garden hose. Need new part with all the interfaces. Where can I purchase and what are the part numbers? Thanks **** McGuire ****.mcguire1@gmail.com
2 Suggested Answers
  • 68 Answers
SOURCE: Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
Posted on Jun 10, 2010
I have a north star pressure washer model 2SFX20ES3 and the pump is not working. The engine is working good. I pull the trigger and no pressure.
Hi
Sometimes you may have to allow a little time for the pump to prime itself and remove the air trapped inside. With the pressure washer at idle and the pressure hose fully extended, squeeze the trigger and see if you get pressure in a couple of minutes.
If you get no joy from that, your pump has likely checked out on you.
Hope this helps.
-Steve
Jun 05, 2015 | Garden
P1800s-BB no water comes out of garden hose with coupler attached
Remove the fittings and check the internal screens, probably rusted and or clogged.
Jul 04, 2014 | Stanley 1800 PSI 1.4 GPM Electric Pressure...
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
Jun 11, 2010 | GE WBSR3140DW Top Load Washer
May 31, 2010 | Northstar Professional Series Pressure...
I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
Mar 03, 2010 | Garden
I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Feb 05, 2010 | Honda Maxus Prosumer MX5223 Pressure...
No pressure on hose
i have a karcher pressure washer i had to change the fuse box and pressure coils hope this helps .tom
Aug 19, 2009 | North Star Garden
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
MyCrosley top loading washer,model CW7500 20 overflowed twice.
ok try this look under the washer between the motor and the transmission is a motor coupler it may have broken to get to it you need to remoe the motor and the pump very easy job but look between the motor and the trany and you will be able to see the coupler it should be two plastic coggs with a rubber coupler this is usually the problem
Jan 08, 2009 | Crosley CCW5294W Top Load Washer
Garden Logo
269 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
