Condenser Unit not working
After a brief neighborhood power failure Friday evening, the outside unit of my 5 y.o. Lennox heat pump (Merit Series) isn't working.  I can spin the fan freely by hand.  I want to check the capacitor, using a standard multi tester. My HVAC person will be here Wednesday, so I have til then to solve this.  Am I on the right track? I've double checked breaker box, thermostat & cleaned the outside ''kill'' switch. Inside unit is working fine.
Sweating in Atlanta (Liz)
  • Heating & Co... Master
  • 1,658 Answers
First check for high voltage on the contactor. If 240 present on bottom is 240 present on the top? If no 240 on top then the contactor is not pulled in. Check for 24 on the sides of the contactor. If no 240 at all then its a breaker or fuse
Posted on May 25, 2017
    New Friend:
  • 117 Answers
Check to see if there is any board in the outside unit with a fuse .Maybe the fuse popped causing the unit to stop working .
Also check to see if you are getting 24 volts on the thermostat wire going to outside unit .
  • 290 Answers
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Posted on Nov 20, 2007
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 478 Answers
SOURCE: Amana 1 ton Residential AC / Outside unit comes on for a sec
open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
Posted on Mar 12, 2009
  • 3361 Answers
SOURCE: Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Posted on Apr 28, 2009
  • 284 Answers
SOURCE: heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
Posted on May 26, 2009
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
New inverter reverse cycle leaking water out the front of the unit. Its 44 degress outside, could this be the problem?
Is it leaking out of the evaporator(inside unit) or condenser?
If it is leaking from the outside unit on defrost then it is normal, if it is leaking from the inside unit then you have a blocked condensate drain tube!
These units defrost from time to time and is normal, it is actually melting the ice that can form on the condenser when it is cold enough outside, it has to initiate a defrost cycle so that air can flow through the condenser again after the cycle is complete.
Then it will return to normal heat pump mode, this is assuming that you have a heat pump.
Jan 11, 2010 | Fujitsu Electronics - Others
Auto burners wont come on my lennox merit series hvac unit.
At whic step does it sto at and theres your problem. step-1 thermostat calls for heat and vent fan turns on.... step--2 the glow plug or hsi lights ... step-3the main gas valve comes on and heats the box...step-4 when the box heats up it closes a temp. switch to start the main fan motor!
Dec 21, 2009 | Honeywell Heating & Cooling
My Lennox Air conditioner only heats
It is possible that it's the thermostat. When you turn it into cool mode, does the unit come on at all or is it silent? If nothing is coming on, then it's likely it's the tstat. Did the tech check the refrigerant charge while he was there? He should have checked it with the auxillary heat off and the unit just in heat mode. Make sure that the condenser unit outside is coming on when you are calling for cool, If you turn it on and everything comes on, go outside and put your hand on the large copper pipe coming into the unit. In cool mode, this pipe will be cold to the touch and in heat mode, the pipe will be warm to the touch. There isn't much you can do on your own with the exception of changing the tstat. If you can answer some of the questions I have posed, I can try and give you some more answers. Just remember that a check up doesn't mean its a guarantee that something won't happen the next day, it's just that everything was in working order at the time of the checkup.
Mar 21, 2009 | Heating & Cooling
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
I need to adjust the limit switch on a Lennox heat pump. How to I turn off power to unit before I open the control cover?
If you mean the ambient lockout switch it shpopuld be oin the outside unit and all that you will need to shut off is the outside condenser before you open the panel. ther is a disconnect that you will have to throw either right by the unit or inside of a main breaker panel.. Hope that this helps and Thanks for using Fixya
Dec 25, 2008 | Heating & Cooling
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
