Question about Craftsman Rear Mount Tiller
Tines go around but wheels are locked in position and won't move
The wheels are locked and won't go forward or reverse..I have to load it up on 2 wheeler to move...but the tines still function and revolve but the wheels won't go into gear...it is a craftsman rear tine tiller 6.0 hp / 14" model 917296020
  • 513 Answers
The gears in the transmission are possibly worn out if i can further help e-mail wade at wadembly@aol.com
Posted on Jun 28, 2009
  • Justin Case
    Justin Case May 15, 2011
    The smaller of the transmissions two internal drive chains is broken and wrapped around one of the gears.
Cub Cadet RT 65 rototiller wheels aren't engaging
It's possible you have snapped the shear pin in the transmission shaft.
Jan 25, 2018 | Cub Cadet Garden
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
My tiller does not seem to be cutting deep enough
Hi there kimberly,
Here's what you need to do.
  • Make sure the depth stake (behind the tines) is up as high as it will go. This will allow the tines to go deeper.
  • Fire it up. Set the tine rotation to reverse (more mixing and twisting.
  • Make sure the tines are actually turning, Each side is held in place with a shear pin. In case something binds the blades, this pin breaking will save the drive train
  • Note how the tiller is balanced. Wheels in the middle. You can tilt it forwards or backwards.
  • Tilting forward allows the wheels to gain traction and move the unit forward
  • Tilting Backwards allows the tines to dig in. If the surface is too hard, Press down with your body weight. It will dig through.
I hope this work out for ya
Best regards
Mike
Apr 25, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
MTD Mastercraft rear tine tiller transmission problem
adjust the spring tension on the ratchet assembly as you are supposed to be able top pull it back against the drive action
May 29, 2017 | Mtd Garden
I have power to the tines but the wheels are locked
Tines only spin in the T position.with cutch engaged.If thats not it split the case and check to see the shift fork operating properly. Or that chains are not broke. NOTE This is a serious job!!!
May 11, 2009 | Craftsman 8.50 Torque Rating Dual...
Craftsman Rear Mount Tiller Logo
486 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
