Surround Speakers Out
I have an Onkyo HT-R340 AV receiver. Recently all the speakers quit working except the front left and right. The center channel, sub and rears are no longer working.
Raveler
  • 36 Answers
SOURCE: Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Posted on Dec 31, 2007
SOURCE: Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Posted on Jan 01, 2008
SOURCE: Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Posted on Mar 10, 2008
ebackhus
  • 31 Answers
SOURCE: 3 speakers dont work
Check to make sure that Speaker B is not pushed. It's on the front panel on the bottom left.
Posted on Jan 04, 2009
guitarman002
  • 80 Answers
SOURCE: I was given a Sharp HT-DP3000 reciever and all the
Do you have speaker wire if not you will need some, the wire is cheap about $5 bucks a roll your local department store will have it. You see a red and black tabs on the back of the unit and on the back of each speakers you push down and stick one wire in the hole. red will be your + and black will be - The two surround go on the back wall behind your seat.The center will sit on top of TV and the sattalite speakes go beside the left and right side of TV. and the sub sits on the floor in hidding behind something or under a table. (P.S, Make sure the wire is shaved about 1/4 of inch before you stick in the wire DO NOT plug the power cord in, intill you hook up all the speakers this could damage the unit. You do not need a sub woofer, if you have one great If not don't worry that will not damage the unit it has a internal switch to turn on/off the sub woofer The sub woofer offers extra deep bass that you can't get from the sattalite speakers.)
Posted on Aug 31, 2009
Can I add more speakers to my HT-J5500W Samsung sound system.
The HT-J5500W can only support a 5.1 speaker system. The main part of the entertainment system supports a direct connection with the front right, front left and center speakers and sub-woofer. The wireless receiver module connects the surround right and left speakers to the rest of the system.
You would need a different amplifier/receiver to switch to a 7.1 or other speaker system using more speakers. You may be able to upgrade the individual speakers, as long as you don't exceed the power output limits of the system. The original speakers are 165 W each (front and surround speakers) and 170 W for the center speaker and the sub-woofer.
I hope this helps.
Mar 04, 2018 | Samsung Audio Players & Recorders
Hookup
It would help to know what equalizer you have, but I will assume it is a stereo analog unit. With the exception of the Tape In/Out connections on the back of the receiver there is really no provision for an equalizer. Even the Tape I/O connections are of little use if you can't monitor the source through the Tape In connections. Even if that were to work, it will not function for any digital sources you may have. You should be able to install this between an analog external source and the input to the receiver if you have one particular device you would like to tweak.
There are equalizer settings you can control within the receiver itself. You have the option of selecting the manual method for equalizer settings for each speaker or the default automatic method. Granted there are only 5 frequencies (3 for the sub) that you can adjust, but the fact that you can adjust each speaker separately is an advantage. The following was taken from the owner's manual:
• The front, center, surround, and surround back speakers
can be adjusted at 80 Hz, 250 Hz, 800 Hz,
2500 Hz, and 8000 Hz. The subwoofer can be adjusted
at 40 Hz, 80 Hz, and 160 Hz.
• While the Direct or Pure Audio listening mode is
selected, the equalizer settings have no effect.
• This procedure can also be performed on the AV
receiver by using its [SETUP], [ENTER], and arrow
buttons.
This is a very good receiver with some great features. If you have performed the Automatic Speaker Setup, you can go to the equalizer setting and select Off, Audyssey (automatic) or Manual.
Hope this helps.
Oct 15, 2008 | Onkyo HTR500 Receiver
Why do only half of my 16 speakers work throughout my home?
Your (5.1) receiver supports just 6 speakers. Left, Center, Right, Left Surround, Right Surround and Subwoofer.
http://redirect.onkyousa.com/redirect.cfm?type=own_manuals&file=TX-SR304_En_0124.pdf
Jan 25, 2016 | Onkyo TX-SR304 Receiver
Surround sound speaker outlets are not working
Hello, I am sorry about your issue. If the speakers work on other terminals then it sounds like a problem with the receiver. It would need to be serviced or traded in. Please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jun 24, 2017 | Onkyo HTR500 Receiver
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo TX-SR605 Receiver
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
Dec 31, 2007 | Onkyo HT-SR800 System
Dec 31, 2007 | Onkyo HT-S680 System
Onkyo srtx601 receiver
Please add a comment to your previous post next time, it makes it easier to see this post has a relevant history. I had to go check in your profile when I saw the word "still". Shooting in the dark, and saying the obvious(just bear in mind a month ago I was going crazy over a problem that ended up being the blanace knob turned to the right) - could it be that you're not using a digital signal? I'm not sure you can get surround with analog. Make sure all settings are for digital, and that you're using a coaxial/optical cable going from the DVD to your receiver. I hope you'll end up embarassed but happy. Good luck
Jun 17, 2006 | Onkyo TX-SR601 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
114 people viewed this question
 Grubhead
Grubhead
