Question about GE J2B915SS Dual Fuel (Electric and Gas) Kitchen Range
Switching from gas to oven
We recently bought the GE Dual fuel range but are having difficulty getting the range to switch from gas to electric. The outlet where it plugs in is working- it IS plugged in. We have contacted Sears and GE, but no one has been able to help us with this problem. Is there a way to switch from gas to electric? According to the user guide, it was set up to be used with electric and the manual tells you how to switch to gas,but this one started out being gas and we cannot get it back to electric. Any ideas?
Thanks!
  • iwantoscream Nov 03, 2007
    Maybe I didn't explain the problem clearly. The oven itself is currently only functioning using gas. We cannot switch it back to electric. I understand that the stove top is gas, but the oven can be used with gas or electric. My question is, how do you switch from gas to electric?
    Sorry for the confusion.
  • luckeduck Mar 13, 2008
    I have the same situation, I recently bought a dual fuel GE Profile P2B912. I was thinking the oven would preheat using gas, then once up to desired temperature would switch to electric. But it doesn't switch to electric. If temp begins to drop the gas burner kicks on again.
  • 100 Answers
Your model stove is dual fuel. Which means that the burners on the top of your stove are run using gas, and the bake and broil (and possibly a warming draw) are run using electricity. So if you are cooking on the top of your range you are using gas, and if you cook in the oven you are using electicity
Posted on Nov 03, 2007
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Oven shuts down
they both use 220 and , you have to put it on different breaker , that can handel 32 amps.
Feb 26, 2014 | Viking 48" 6 Burner, Griddle Professional...
M y dual fuel GE oven has no display showing it just went blank, but when you open the oven door the light goes on
I had the same problem as devlin50 with my GE duel fuel 918 model.
If you trip the circuit breaker off and leave for one minute before switching the power back on then hopefully the panel will be flashing, worked for me. Worth trying as replacement panel is not cheap, about $220 here in Canada.
TonyM
Mar 15, 2011 | GE Profile J2S968 Dual Fuel (Electric and...
Tin foil stuck to bottom of new ge monogram oven
I had the same thing just occur. GE is now telling me the only fix is to buy a new range. Great. $10K for a range that I use once.
Jan 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Dec 22, 2008 | KitchenAid KDRP463LSS Dual Fuel (Electric...
GAS OVEN
This oven has an electric thermostat control and it is most likely shorted out or the contacts are melted shut......replace the control switch that temperature knob is on it has two wires going to the gas valve.
May 15, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
Five Star Dual Fuel Range Issue
make sure the gas pressure is correct.get a small torch and heat up the flame switch (it sits above the glow bar)and see if the burner lights.
Aug 22, 2007 | Five Star TPN535-BGSW Dual Fuel (Electric...
GE J2B915SS Dual Fuel (Electric and Gas) Kitchen Range Logo
161 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
