Question about InFocus ScreenPlay 61" Rear Projection HDTV
T.V. flashing on and off .
Every few seconds untill it warms up (15-20 min), then it seems ok with just a flash now and then while watching. But if you want to play a game it seems like it does it more often even if its warmed up.Basic watching is my main concern.
  • 643 Answers
Tuner inside tv probably going bad. use an optional input if available.
Posted on Jun 21, 2009
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
I can't set the time. I've looked on-line and still can't figure out the step by step instructions. They don't seem to match my watch which is a women's 1440 Sport watch with gray band.
Hi aausenhus,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Apr 27, 2011 | Timex 1440 Nylon watch
How do i set the time for my adidas ADP6002?
The watch looks and feel great; the band doesn't hurt my wrist like other watches. The instruction book, however, was awful. It was a bunch of instructions for other watches, not the ADP6002. It took a few minutes of playing around for me to figure out how to set the watch. Here's how to do it: 1) Make sure there is a little "t1" above the second hand. If there is a "t2" instead, hold the Start/Stop button for 3 seconds. (This is the part that was messing me up) 2) Hold the Set/Light button for a few seconds. The watch should say LIGHT and "OFF" or "ON" should be flashing. 3) Press the Mode button until the hour hand starts flashing. You can adjust it up and down by the Start/Stop and Lap/Reset buttons. 4) Press Mode to adjust the minute, second, and other settings. 5) Press Set/Light button when you are finished.
Jan 04, 2011 | Adidas Digi III Watch
I cannot set the time in my timex 1440 watch. It came with the wrong directions. The mode button doesn't seem to work.
Hi fransolomon8,
Hope it helps.
Dec 10, 2010 | Timex 1440 Nylon watch
Montior flashes on and off at start up.
This is due to dry solder in the circuit of the monitor or capacitor on the circuit boaed is having the issue. Need to replace/rectify the same with the help from local expert engineers.
Revert back for more assistance. Please give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 12, 2010 | Computers & Internet
I have an activa lithium water resistant watch #AD632=010. The light works but the digital clock doesn't.
If there is no time displayed the watch is just dead. You can try a new battery or just get a new watch.
If you can't seem to set the time: Press and hold Mode until it flashes a time and the letter A . This is how you set the alarm. Press mode again and you can set the time. start stop button moves between seconds, min., hrs, and days. reset changes the value.
Jan 28, 2010 | Activa Watches
Check engine light is on and lately when first starting out in the morning its flashing when pressing the gas. its also missing a little until it warms up. today it lost power going up a hill then...
the flashing light is telling you you have bad misfire,, have the truck scanned to find the cause, will tell you which cylinder it is and thats where ya wanna start,
Jan 18, 2010 | 1999 Ford Explorer
Need help setting the time on my 40/8125
Hold down MODE until date begins to flash (about 2 sec) then press MODE one more time. The seconds begin to flash then press ST/STP to go to min or one more time to go to Hours, when finished press MODE to go back to normal time.
Nov 02, 2009 | Armitron 40/8125BLK Digital Sport Watch
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
InFocus ScreenPlay 61" Rear Projection HDTV Logo
81 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
