Question about Refrigerators
FRT21HR6AB3 SELF DEFROTING DRAIN APPEARS PLUGGED'' BOTH FRI AND FREEZE UNIT WORK BUT WATER FROM FREEZER DEFORST RUNS INTO FRG UNIT. HOW DO I UNSTOP
    Sergeant:
  • 212 Answers
Either pour hot water into hole or i have always removed rear wall. your drain hole is located under the evaporator. take long metal hanger and poke out restriction. very common problem
Posted on Jun 21, 2009
Bottom of freezer has a layer of ice, that returns after removal, no aparent drain or leak
there is a drain hole in the bottom of freezer near back wall if its a side by side. take out bottom crisper drawer to locate drain. than take hot water in a turkey baster and run hot water doen drain hole to unstop drain.
Aug 31, 2014 | KitchenAid KFXS25RYMS 25 cu.ft. french...
Defrost drain is freezing
it is a normal problem with all refr. there is a drain tube at the rear of the unit the has a "drain loop" it gets plugged after a few years. try and remove the tube from the clamp, and run water thru it to clear the blockage. you will also need to remove the ice from under the freezer coil after you clear the tube. after that the regular defrost cycle will take over and work properly.
Dec 31, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
My Kenmore upright self defrosting freezer has been turning itself off and on for a couple of months. There is water on the floor under the unit when it turns itself off. Yesterday, it turned off and...
It appears the timer is fried. The water on the floor could be that the drain pan is out of place. The water should be drain into it and then evaporating . Just slide it back in place. The timer is not that expensive and fairly easy to install. Basically, take it off and put te new one on the same way you took it off.
Mar 04, 2013 | Kenmore Freezers
The Freezer drawer on our new LG LFC25776W is sticking shut. We have tried unplugging the fridge and letting it fully defrost at which point both the main door and interior slide shelf work fine when at...
Sounds like you have a clogged drain or partial. Pour hot water down the drain underneath back panel; until it takes the water without running over.
Check temp in freezer. It probably is freezing the water in the drain.
Temp should be between 0 to 10 Degrees.
Jul 20, 2011 | Refrigerators
Ice build-up in bottom of freezer due to stopped up drain. I Know how to get drain unstopped, but don't know easiet way to melt ice in bottom of freezer. Have tried hair dryer, but I am afraid I am going...
Very common, remove the back panel in the freezer pour hot water down the drain hole. The defrost drain line is blocked, I know this unit very well can help you more if you need, let me know,
http://www.appliancerepairlesson.com/
Mar 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Drain hole stopped up in freezer and we cant get it unstopped and it is leaking down in to frige. do you know how we can get it unstopped?
pull back panel in freezer, take hair dryer and melt ice around drain hole until it starts to drain may take sometime usually 20 30 mins pour hot water in drain pan to verify that it is draining
Jan 03, 2010 | Roper Refrigerators
How do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
Pooling Water
Hi!!!Your drain line is frozen and plugged.Try to remove the cover of the evaporator and you should see a small hole on the base of the evaporator thats yout drain line hole. Blow it away and your problem is gone..Good luckk..Plugged drain line..
Dec 23, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
Freezing drain tube
Sometimes what causes this is a obstruction in the drain line. It may be draining, but not fast enough. the water could still be backed up enough to freeze after the defrost cycle. I would clean the line out with compressed air, or flushing water down it. If there is no progress with this, then you can get a drain line defrost heater. they come in all sizes, voltage, and Watts. You should be able to wire it directly into the defrost circuit
Jan 13, 2008 | Freezers
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
