Question about HP Photosmart C5280 Printer
Printed pages come out with dark lines under each line of print
I have done the "Alignment" a few times. The alignment page, printed pages, or copied pages all come out with a dark dashed line under each line of the copy.
  • 50 Answers
Find your printer's "Maintenance" menu, in its "Toolbox" or from the Start Menu.
Preform a cartridge or head cleaning, that should solve your issue. If not, try replacing the cartridges with new ones.
Hope I helped,
Tom
Posted on Jun 21, 2009
Lines are not aligned when printed
Hi,You need to do a maintenance check on your printer. Go to my computer...control panel...click on printers and scanners..Under here you should have an option for maintenance...You will need to do an alignment check and cleaning of nozzles and printer head. Once this has been done, you can print a test page and the alignment should then be corrected.Hope this helps youKind regardsMichelle
Mar 06, 2012 | Office Equipment & Supplies
My printer shows head alignment problem, what to do? it prints top half of the line only
Go to Control Panel. Click on Printers & Faxes. Right Click on your Printer's icon. Click Properties on the drop down menu. Click Maintenance Tab. Select Print head Alignment. Carry out the instructions displayed. A print test page will be printed after the alignment has been done. Check the printed matter with the sample page. If not OK again carry out the process till you get a clear printed page.
Sep 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
THE FIRST TWO LINES OF A PRINTED DOCUMENT ARE PRINTING DOUBLE.
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
When I change the black ink cartridge, the alignment page and instruction page are printing out fine. When I place the alignment page on the glass as instructed and press 'ENTER', the printer gives a...
I just had the same issue (align page not detected).
We had just re-installed the empty color cartridge back into the printer (long story but basically we knew we could only print B/W).
The align page printout had a lot of empty spaces around the black lines. This is apparently where the color lines are supposed to print.
Without those color lines, the printer would not detect the align page as color is part of the alignment being done.
Since we only wanted black printouts, I pressed 'cancel' to stop the alignment process, and now we just hit the Black copy button and ignore the alignment prompt on the printer window.
The HP site (enter psc750 in product window) has some helpful ideas as to what the problem might also be. It could be the shipping tape is still on the new cartridge (and preventing the black or color from printing on the align sheets) etc.
Mar 20, 2009 | HP PSC 750 All-In-One InkJet Printer
I have a X7170 it has recently began printing with vertical blank areas on the printed copy. In other words up and down on the page there missing copy. I have changed ink cartridges and this does not help....
Uneven vertical lines can be adjusted by
performing the printhead alignment adjustments.
The user is directed through the Lexmark Solution
Center to perform the printhead alignment
adjustments when replacing a printhead cartridge.
The alignment can also be performed from the
control panel by selecting the Maintenance Option,
then Align Cartridges.
Feb 01, 2009 | Lexmark X7170 All-In-One InkJet Printer
Printer prints a test page every time it is turned on.
Hi everyone
After replacing the print cartridges 2 steps need to be done:
1. Wait for the test page to be printed out and
2. Put a page over the scanner glass and press scan button on your
printer.
Turn off the printer and turn it on again to see if the problem was
solved.
Ali Khan
Dec 19, 2008 | HP PSC 1350 All-In-One Thermal Printer
Alignment
I had this problem before as well. I took my ink into the refill store and she steamed it for me and cleaned it up. It then worked great. It had dried ink and wasn't printing proper.
Sep 07, 2008 | Dell 924 All-in-One InkJet Printer
Only top quarter of page is printed
How can a get the # recalled of a document was fax to.
Sep 02, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP Photosmart C5280 Printer Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
