Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Does anyone know what the resistance across the Epson lamp is approximately, when I measure my new lamp it is showing infinite resistance (basically an open circuit) and the TV is still flashing red lamp LED.. Thankyou Jim
    Problem Solver:
  • 6 Answers
The resistance is irrelavant.(cuz it is infinite) if this is a dlp bulb?
they can be crossrefrenced and alot are interchangeable the numbers and wattage on the bulb itself is what you need most common bulbs i can get for 100$-150$ plus shipping,with a guarantee. e-mail the #s and wattage @ ohmega1080@yahoo.com
Posted on Jun 21, 2009
Battery wont stay charged while running put in new battery problem still not staying charged.
Step 1. First things first, load test the battery. Most places like Auto Zone will do it for free. Even if it measures over 12.5 vdc it can still be bad under a load. Battery is typically rated at 19 amp hours and 270 Cold Cranking Amps (CCA).
Start the engine and measure DC Volts across the battery terminals, the regulator should be putting out 14.3 - 14.7 vdc at 3600 rpm and 75 degrees F.
Step 2. To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast.
To do this with a meter which is more accurate: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
Step 3. On the other part of the disconnected regulator plug. Set the multimeter for Ohms x1 scale and measure for resistance across the pins of the stator. You should read something around 0.1 to 0.2 ohms for the TC88 32 amp system.
Step 4. Then check for continuity between each pin on the plug and frame/engine ground. The meter needle should not move (infinite resistance)(digitals will show infinite resistance) if the meter needle does move (indicating continuity)(digitals will show some resistance), recheck very carefully. If the meter still shows continuity to ground the stator is shorted (bad).
Step 5. Set the meter to read A/C volts higher than 30 volts (the scale setting for voltage should always be higher than the highest voltage you expect or you may fry the meter). Start the bike, and measure from one pin to the other on the plug (DO NOT cross the multimeter probes! - touch them to each other). You should read roughly 16-20 vac per 1,000 rpm.
Step 6. If the battery was good under load test, if the stator is NOT shorted to ground, and the stator is putting out A/C voltage, then the regulator is bad (most likely even if if passed step 2).
Jul 24, 2011 | 2001 Harley Davidson XL Sportster 883...
How to get cartridge out of original shower part to replace new danco part
Jul 24, 2011 | Danco Home
My kyocera say call service error 6000 what can i do?
Broken heater lamp error
The temperature won't rise by 1°C/33.8 °F during warming up and the heater is turned on for 5 seconds.
The temperature won't rise by 1°C/33.8 °F during printing and the heater is turned on for 5 seconds with the duty cycle more than 60%.
1. Defective fuser thermistor.
2. Broken thermal cutout or heater lamp.
3. Defective engine/high voltage PWB.
Turn power switch off, and remove power cord.
Detach YC7 connector on the engine/high voltage PWB.
Measure resistance between pins 1 and 2 of the detached connector.
Open (infinite)?
Yes Then - Replace the fuser thermistor.
No Then - Detach YC1 connector on the power source PWB.
- Measure resistance between pins 1 and 2 of the detached connector.
Open (infinite)?
Yes - Replace the thermal cutout or heater lamp.
No - Replace the engine/high voltage PWB.
I hope this was helpful,
Shawn
Mar 06, 2011 | Kyocera FS-1016 Printer
How can I resolve kyocera fs 1016mfp error 6000? thanks
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Follow the flow chart:
remove power cord.
PWB.
Measure resistance
Open
(infinite)?
Yes ---> Replace the fuser thermistor.
NO ----> Detach YC1 connector on the power source PWB.
Measure resistance
Open
(infinite)?
Yes ---> Replace the thermal cutout or heater lamp.
NO ----> Replace the engine/high voltage PWB.
Sep 01, 2010 | Kyocera FS-1016 Printer
My 2006 kenmore elite dryer wont turn on
The F40 code indicates a communication problem between the main machine control and the blower motor control board. According to your symptoms, it is likely that this problem is being caused by a blown thermal fuse. I recommend the thermal fuse for continuity.
Unplug the dryer before accessing this component. Access this fuse and pull one wire off. Measure the resistance across the leads of the fuse using a volt/ohm meter. You should measure near zero ohms of resistance (continuity) if the fuse is good. If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.
NOTE: If the thermal fuse is blown, check for a restriction in the exhaust vent to the outside of your home. This type of problem will cause the fuse to blow.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3390719.
This should fix your dryer problem.
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Audio-Technica AT2020 low audio output
Pins 2&3 are the correct ones to use for checking the voice coil. Pin 1 is chassis ground and should always read infinite resistance to the other two.
That microphone has an impedance of 100 ohms, so if you are reading 30 ohms you clearly have a problem with the voice coil.
Good Luck
BB
May 16, 2009 | Audio Technica Audio-Technica AT2020...
Panasonic PT40LC12 - Blinking green power light - no lamp fire up.
Had similar issue but had high resistance across leads. replaced with thermal fuse from RadioShack in the similar temp and everything works great. Info on the original part is on this link. http://www.willas-array.com/prod/products/directory/pdf/sefuse/FUSE_SMG.PDF Hope that helps. Chris
Apr 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Lamp
I have the CP-X275W that did the same thing. The ballast was bad and I fixed it with a $5 switching regulator. The CP-X327 has the identical ballast.
Details:
The High Intensity Discharge Metal Halide lamp suddenly failed to light up. A new lamp was installed and would not light up either. The fan ran and the lamp LED flashed after a few minutes. Voltage to the ballast module was 368VDC. The ballast did not pulse.
Ballast# PS-226-LS-210 was bad. Hitachi Part# HA01101 has been discontinued and the new part number is HA01102. It was $210USD at Vance Baldwin or $221USD at Part Solver.
The FET series (TR1,5,6,7,8,) seemed good: (drain-source resistance=5Kohm). Bought an identical projector on Ebay to do comparative multimeter measurements. Found resistance differences in IC01 (STRG6153). Swapped good part to bad projector, and it worked. This is a 5-pin Sanken brand switching regulator, US$5 at www.electronix.com. They have the STRTG6153, which is compatible, and may be better. The bad one removed from the circuit measures 15Kohm on pin 3 to pin 5 and the same 15Kohm when the probes are reversed. The good one measures 18Mohm and infinite when the probes are reversed.
If you would like me to fix it for you and clean all your optics, I can do it for $150USD plus $25 return shipping. Contact Chris at chris_goulet@yahoo.ca.
If you have a new lamp for sale I would buy one for $100USD.
Good luck.
Dec 22, 2006 | Hitachi CP-X327 Multimedia Projector
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
122 people viewed this question
Top Epson Televison & Video Experts
Eric Sutherland
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
