Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Same here david! ARCHOS DVR STATION GEN 5 REMOTE NOT WORKING
That's what i've been doing too...nothings happening. i thought it was as simple as plug and play. but my remote wont work as well. ive never dropped it or anything. looked in the archos 604 if there should be like a connection pairing but no. it just wont work.
please fixya...help us with this. i really love my archos...but the remote just wont work...
help us please... =(
  • DISH Network Expert
  • 246 Answers
Hi g tongsonmy name is Mike Houston of DISH Network and I was going over your post and seenwhere your Archos DVR is not working with the remote. If your Archos is sync tothe DISH Network receiver and all the functions still are not working you willneed to call Archos and I will give you the number. Archos (Pocket Dish),8773008879
Posted on Feb 14, 2011
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
Feb 06, 2011 | Computers & Internet
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Hi.. i have an archos gen 5.. for the 1st year i could record from the tv listing for free. now that year is up and i can't seem to find out how i can get the tv listing to upgrade. so i can start...
Go to www.archos.com
My Account - and logon
Manage Products
Product Services
Scroll down to TV Program Guide available for owners of DVR Station Gen 5 and press Update
That will take you to the TVTV website where you can pay for another year's subscription. Currently around £14.
May 06, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
DVR to Archos
That's what the DVR does. All you need to do is play whatever program you would like on your cablebox/DVR and hit record on your archos. It will record it like any program.
DamPinou
Mar 25, 2008 | Archos 605 WiFi Digital Media Player
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Troubleshooting
my archos stop connecting to my pc by usb
Jan 09, 2008 | Archos 605 WiFi Digital Media Player
Archos dvr station remote control
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, TRY SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 ( B676 ) THIS DID TURN OFF MY SAT RECEIVER BUT THEN ACCIDENTALLY SCREWED UP THE NEXT STAGE AND I CAN NOW NO LONGER TURN THE SAT BOX OFF,
BUT YOU MAY HAVE MORE LUCK, IF YOU DO NOT SCREW THE NEXT STAGE UP, BEST OF LUCK
Nov 30, 2007 | DISH Network ViP622 DVR DTV Receiver /...
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
262 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
