Question about Canon Rebel XT / EOS 350D Digital Camera
Progressive flashing/whiteout of LED screen
Yesterday I was working with my 350D XT when a jagged section of the upper left corner of the LED started flashing white . Over the course of the day, I looked up all the possible errors that the XT can generate, and could find nothing. In the interim, the jagged white section continued to grow, until this morning, the entire LED is whited out. I changed the lenses and the CF card, no change.
Any help would be appreciated, as I like this camera a lot.
Thanks for your time,
Fran
  • franimaldoc Jun 27, 2009
    Thanks.
    I've sent an email to Canon asking for their input and information about any support they offer for the problem.
    I'll let you know what they say.
    I appreciate the time you've taken in answering,
    Fran
  • 495 Answers
To reset factory defaults. Turn the dial to P (program). Turn on the camera. Hit the menu key. You will now see the extended menus. (if you don't turn to P you only get basic menu). Go to the last tab which is the second tools menu. Look down the menu and you'll see a "clear settings." Select this and you have two choices "clear all camera settings" and "clear all custom functions." Select "clear all camera settings." The "clear all custom functions" only applies if you've created custom functions which few people do. I hope this helps.
Posted on Jun 27, 2009
    Genius:
  • 1,847 Answers
The camera could have problem with LCD as this sign is of the LCD getting old but if you also have problem when you see the image in your system means the problem is that of CCD sensor, please check what exactly is this, in either case my suggestions would be to take a call on service if CCD the Canon Company must have some free replacement policy but if LCD then could be paid one.
Do let us know if any further support is required.
Thanks
Kindly rate the answer
Kevin
Flash won't work...flash icon on screen flashes when shutter button is depressed
try a reset of all options to default. It's possible that it has been set accidentally wrongly
Nov 09, 2013 | Canon Rebel XT / EOS 350D Digital Camera
How to reset sound logic xt netbook
i NEED TO RESET my sound logic tablet
Feb 23, 2013 | Tablets & eReaders
Brand new canon slr camera. can't see a live pic on led
Canon 350D can only take picture it does not take video. On screen of course you can play the photos you have taken. But that is all.
Feb 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
When I try to take the pic the #5" comes on and flashes at the upper left hand corner. I tried turning the camera off and it still is flasing. I turned the camera off then opened the door to the CF card...
If you hear a click and then get Error #5 then either the flash is not popping up as it should or the two little switches under the flash are stuck. Gently help the flash up, then turn the camera off and on again to clear the error message. I found the hinge on my flash was corroded, probably due to getting sea water in it. Hope that helps.
Sep 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XT: The upper lcd screen info flickers,some of the icons on the screen work normaly, but other icons are lighter and flicker. Im speaking about the portion that displays battery...
It seems you have a false contact in the upper LCD screen, its flat ribbon cable or the connector at the main board.
It is necessary to open it and check it.
It is fairly easy to do it, but if the camera has a warranty, I do recommend you to make it valid.
If does not have warranty, then you may try in do it yourself if you have some experience and skills to fix electronic devices, or pay to have it done.
Best regards,
Jun 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Sounds like loose part in Canon 350D / Rebel XT
This is nothing to worry about. The sound is made by the metal linkage inside the flash housing. Pop up the flash and touch the linkage with your fingers. You will see there is a little movement. This movement is enough to make the sound you hear.
Jun 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Cannon eos 350D rebel xt. digital viewfinder is black
well its a common problem that happends with these models also the meta display most be gone I recommend to take it to a local repair shop and have them look at the back cover
Nov 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Shadow across photo
Shadows, especially circular shadows, are pretty common with the pop-up flash. What you are seeing is actually the shadow cast by the end of the lens. This happens especially on wider angle shots.
The solution is to find a way to get the lens out of the way of the flash. You can get an external flash, like a 430ex or 580ex, which elevates the flash far above the lens. That is an expensive option so first you might try making a diffuser for your pop up flash, which softens the source of light and helps eliminate some shadows:
http://www.diyphotography.net/diy-built-in-pop-up-flash-diffuser
http://www.flickr.com/photos/natuurplaat/10362363/
Dec 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
161 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
