Question about HP vs17c 17" LCD Monitor
Hewlett-Packard vs17 half fixed, what to do next?
I am attempting to repair a Hewlett-Packard vs17 LCD monitor. When I initially examined the inverter circuit board it was evident that 4 electrolytic capacitors had failed. They were replaced and the monitor went from having a blinking blue power button and showing absolutely nothing to a state where the power button remained on without flashing and the expected images were displayed on the screen for about a second before fading to black. I again the removed the inverter board . Upon close inspection, components of the circuit board show no obvious damage. There are no areas of darkening on the board. There are no hints of thermal damage whatsoever. I understand that cold solder joints may present problems and I inspected the board as closely as I can and have not found any. If this were a Benq inverter board I would know which joints were most likely to be problematic but for this board I have no idea. Without some evident sign of damage I am unsure of how to proceed. One additional piece of information that may or may not be of any importance is this fact: the monitor in question had been running for several years without being turned off. There was no problem with picture quality or brightness. Only after being turned off and attempting to restart it did the monitor display no picture and a flashing power button. Can anybody suggest what steps to take next?
  • HP Master
  • 1,684 Answers
I have also seen this type of problem. Have you checked the large caps on the inverter board, no just the power supply board? Many LCD monitors have 2 caps on the inverter and I have had to replace them from time to time. The next thing to check would be the driver transistors. I hope this helps.
Buddy
Posted on Jun 23, 2009
G4-1215dx screen is dark
A dark screen means the inverter maybe faulty or the CCFL lamp at the bottom of the LCD is faulty.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 03, 2013 | HP recertified pavilion g4-1215dx laptop -...
Tip
What is a Scanner Error 5 Hewlett Packard M2727nf MFP
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M2727
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
This printer is under HP Warranty until Mar 23, 2011
Contact Hewlett Packard for Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
2 parts need to be replaced at the same time
Parts Required as follows
Formatter - CC370-60001
Scanner/Flatbed - CB532-67905
Warranty Extension Expiration 2011-03-23
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
Hewlett Packard Laserjet M1522
Contact Hewlett Packard for possible Warranty repair. See Link Below
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
How do I fix the HP Pavilion g6-1b70us flickering issue?
The problem is in the inverter board or the backlight behind the LCD is going. Hook a spare monitor to the video output usually on the back , if pictue okay! the problem is in the above mentioned, but if both screens show the same symptom the Video Graphics Card is the problem, you can reduce the brightness to off set the flicker, "might work"
Mar 22, 2012 | HEWLETT-PACKARD HP Pavilion G61b70us...
Hp laptop only half a screen
Hook a spare monitor to the video output on the back, if picture is okay! it means the LCD panel is defective and screen must be replaced, however if same symptoms show on spare monitor it indicates a bad video graphics card normally built into the motherboard.
Mar 05, 2012 | HP Hewlett Packard Compaq 6710b Notebook...
Sound no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!,.,.
May 10, 2011 | HEWLETT-PACKARD Hewlett Packard LD4200 42...
Hi, The problem with my Monitor is that after the
That LCD monitor uses a fluorescent backlight, and the symptom you are seeing probably means the backlight is failing. There are two possible problems:
1) Likely: The inverter board is failing. The inverter creates the high voltage needed to run the backlight and can shut down after a short time if the board is failing.
2) Less likely: The fluorescent tubes themselves are failing. This usually requires replacing the whole LCD screen, although experienced technicians can disassemble the LCD screen and change the bulbs. This is much riskier.
The best bet is to replace the whole monitor. If you are willing to take apart the monitor and try a repair, you may be able to get an inverter and fix the problem.
Sellers on eBay usually carry a lot of models of inverters and may be able to sell you one and guide you through a replacement. However, this is a moderately advanced repair.
Search for the HP exact model and "inverter" on eBay
Apr 11, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Monitor hpvs17e stays on for second and goes blank
gldngrlz411, most likely problem with internal "switch-mode-power-supply" / CCFL inverter supply that provides 600 to 1000 volts ac to light the CCFL tubes that provide "white light" so you can see what is on the glass LCD panel!! Explore here first: http://www/lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ If vs17e does same when connected to a different "known good" pc, then you will need to make big decision!!! FIX or Trade in for new wide screen unit. 12fixlouie
Oct 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My monitor, when turned on, flashes a functioning
It can be bad caps or bad soldring works on the lamp, see what I fixed here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
You will nees spare lamps for testing to find out if the problem is in the inverter or the lamps.
Feb 19, 2010 | HP vs19 19" LCD Monitor
HP vs17c 17" LCD Monitor Logo
258 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
