Question about Maytag MSD2756G Side by Side Refrigerator
I hear buzzing sound and a click like a switch when the compressure turns on.
  • Maytag Master
  • 4,655 Answers
Then you will need to get that fixed. Sounds to me that your start relay and start capacitor are not making good start connection and the overload is clicking out. If you don't fix this problem soon the compressor may be damaged. I need to know if your model is the MSD2756G or a different model. Let me know..Sea Breeze
Posted on Jun 21, 2009
  • 6,784 Answers
HI, this is an early sign of Relay/overload assy failure. if the compressor is still operational at this pitn, it will need ot be serviced soon. If the compressor is not operational, i recommend replacing the Relay/overload assy.
My mazda buzzes 2 times when I turn the headlights off and the instrumentation lights flash at the same time
Mazda 626 Electrical Issues - Car Forums at Edmunds.com
forums.edmunds.com > Mazda > Mazda 626
May 22, 2007 - 31 posts - ‎24 authors
clicking or buzzing sound coming from the "headlight relay" which is in ... off when you turn on the headlights then it clicks instead of buzzing in that fuse compartment and the headlight flickers about 5-10 times a second in time with the ..... I have a 1992 626 mazda, the battery died and replaced it two days ...
Thread: headlight issue and buzzing sound - Toronto Mazda 3
www.torontomazda3.ca > Forum > Technical Section > Electrical
Mar 3, 2009 - 25 posts - ‎10 authors
1. so in the fall my right headlight burned out, but then after nudging ... 2. sometimes when i turn off the car i hear buzzing coming from .... i turn off the car, was never able to open the hood in time before the sound disappears ... Buzzing sound behind centre console
Sep 17, 2010
HID Problem: Bulb/Ballast Misfiring
Aug 28, 2010
Buzzing relay after HID install with RELAY harness ...
Mar 12, 2008
More results from www.torontomazda3.ca
Jan 07, 2016 | Mazda Cars & Trucks
Any ideas ?
It would be the fuel pump priming before cranking.. The clicking sound would be the relay that switches on and off when it reaches the required pressure.. When the motor is running, it would continue running to provide fuel pressure..
Jul 19, 2014 | 2004 Yamaha V Star Classic
When I turn on the blinkers , , I hear a buzz sound , and then the insturment panel lights up ?
I just had a buzzing sound happening on my 2000 Monte Carlo. It was coming from the Hazard button which is actually combination blinker\hazard switch in one. Turns out the ignition switch was going bad. The ignition switch finally went totally bad (no start some times). Changed it a couple of months ago. No issues with blinkers again.
Sep 05, 2012 | 2000 Chevrolet Monte Carlo
Transmission buzzing
Click this link below to troubleshoot the buzzing noise problem from transmission:---http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
--------This will help.Thanks.
Feb 19, 2012 | 1999 Toyota Camry
Ac turns on and the fan blows air but not cold air. When switching from fan to ac mode i hear a buzz sound like it had switch to ac but still its not blowing out cold air. Any suggestions?
mcdevito75, Needs service either a chrge of freon or the need for a new thermostat and That is what it sounds like to me, (the compressor could be bad also, the buzzing sound) hope not expensive repair.
Jun 23, 2010 | Amana PBC101A00A Air Conditioner
NO PICTURE OR SOUND
The buzz is the power supply attempting to power the set. The click is the unit shutting down. Can you pleae post the make and model as well as whether or not the standby light is blinking? With that info we should be able to give you some options.
Thanks,
Dan
Nov 03, 2009 | RCA Televison & Video
Aprox every 5min I hear a click when turning on followed by a buzzing sound when running followed by a click followed by a click when shutting off could this be a relay
thats exactly correct,
it sounds like a snap, when it turns on
the buzzing hower is telling you its either going
or on the way out that buzzing is usually voltage arc on a bad or loose connection make sure the relay on the compressor is tight
Oct 02, 2009 | Refrigerators
I have a 2003 chrysler sebring was running good and suddenly died
Check for Fuel Pressure @ Test Port if it Does not SPRAY Fuel Pump is Bad
May 31, 2009 | 2003 Chrysler Sebring
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
98 Buick Lesabre Blinker Problem
If ALL Wiring in Trunk is Good Then Its The SWITCH = Multifunction Switch<<
Feb 11, 2009 | 1997 Buick LeSabre
Maytag MSD2756G Side by Side Refrigerator Logo
317 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
