Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark X6150 says balck cartridge missing
I installed a remanufactured black cartridge in my Lexmark X6150 printer and received the message that the black cartridge is missing.
Must use a new cartridge.
Posted on Jun 23, 2009
I have replaced black ink but printer keeps telling me to replace black ink cartridge
If the it's a remanufactured cartridge (not genuine), the printer will not detect the ink in the cartridge.
If it's genuine, you might want to give Lexmark's technical support a call to have the cartridge replaced.
May 05, 2012 | Lexmark X4650 InkJet Printer
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
My black ink all of a sudden won't print and I get an error message that says remove tape from cartridge...there is no tape...it is a Lexmark 6150
If the problem continues even after re-seating the black cartridge and cleaning its nozzles, then it could be a faulty cartridge issue. Replace it with a new genuine Lexmark cartridge.
Aug 23, 2011 | Lexmark X6150 All-In-One InkJet Printer
Replaced black ink cartridge (not lexmark brand) printer will not recognise it even though supposed to be compatible?
For the most optimal output experience with your AIO, Lexmark recommends that customers update their firmware. The firmware helps ensure that customers receive the highest yields of ink available from the cartridges, which offers the greatest value and means fewer necessary cartridge replacements.
If you choose to upgrade firmware, note that unauthorized use of third-party 'cloned' cartridges will no longer be possible.
When purchasing ink cartridges, Lexmark customers have two options:
Regular ink cartridges without license terms that they may a) return to Lexmark free of charge (for recycling by Lexmark), b) refill, recycle or remanufacture themselves, or c) provide to third parties for refilling, recycling, or remanufacturing. Any Regular ink cartridge can be refilled by a customer or a third party and will continue to work in their Lexmark printer.
Return Program ink cartridges that provide customers with an up-front discount in exchange for their agreement to use the ink cartridge once and return it only to Lexmark for remanufacturing and recycling.
Jul 11, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Receiving printer error code 5020..wht does it mean and how is it corrected?
The error indicates either an unseated encoder strip or a faulty black or color cartridge. Please refer to this article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the troubleshooting steps in the article, please contact Lexmark technical support for additional help. Thanks.
Dec 27, 2010 | Lexmark X6150 All-In-One InkJet Printer
I have installed 2 new cartridges & the black prints but the color will not.
i have only one balck cartridge in lexmark x2690 one cartridge is lost then my printer is not start the printer message is one cartridge is installed then i want a one cartridge is lexmark x2690
Jan 22, 2010 | Lexmark X2690 All-In-One InkJet Printer
What is an error message 502?
The 0502 error can be caused by four different issues:
  • A contaminated encoder strip
  • An unseated encoder strip
  • A faulty black/photo cartridge
  • A faulty color cartridge
If the printer is still under warranty, it is best to replace it, as error 502 is usually recurrent. Otherwise, please follow the link below to the Lexmark website for a detailed troubleshooting guide for error 502:
I hope this helps.
Nov 19, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark printer 810 series what number for a black ink cartridge
series it would be 18C0032 (Lexmark 32) Black remanufactured cartridge 18c0032.jpg
Apr 03, 2008 | Office Equipment & Supplies
Lexmark printer x6150
I had the same problem and used Solution #3 (above) from a "Guest". Since I was only immediately concerned with printing in black, I took out the color cartridge and the printer is now working fine!
Apr 03, 2007 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
307 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
