Question about Foxconn P4M800P7MA-RS2 Motherboard
VGA controller not working - Foxconn P4M800P7MA-RS2 Motherboard
  • 50 Answers
Make sure it's not disabled in the BIOS.
If it's enabled, it's probably faulty and you probably have no choice but to replace the motherboard or add a video card in one of the slots.
Hope I helped,
Tom
Posted on Jun 21, 2009
No signal input wen connected to the VGA port of my Dell M1210 (Win 7). using an VGA to DVI cable. If i connect the CG223 to an old laptop (vga) it works fine.
The Dell M1210 hos only a VGA output or s-video output, both being analog. If you are connecting the M1210 VGA to the DVI input on the monitor then this will not work. You need to connect to the VGA input on the monitor.
May 25, 2011 | Eizo CG223WBK Monitor
VGA Audio Controller
it has in-built drivers just try to reload the drivers! it will work fine
Jul 10, 2010 | Compaq Presario M2000 Notebook
The video of my laptop does not working properly
You should update your VGA driver.
Update of VGA Driver.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on Display Adapter
  • After this Right click on VGA Driver
  • Click on Update Driver.
  • Update Driver Wizard start.
  • if the problem is still exist.
  • Replace the VGA or have a local tech take a look at the VGA.
  • Toshiba Notebook Drivers
Mar 21, 2010 | Toshiba Satellite A105-S2051 Notebook
I can't seem to get my Gigaware VGA PC Camera to work
Hello, try going into your start menu on the bottom bar of you computer. From there click on your controle pannel, in your controle pannel you will find an icon that says ADD HARDWARE, open that and follow the prompts. This should hopefully work for you. I hope it helps.
Nov 05, 2009 | Radio Shack VGA PC Camera Webcam
I want vga controller for my gateway notebook
Go to the gateway website, look for a support or download section, find the driver download it and install it....that shouuld work
May 16, 2009 | Gateway OBS Sound Card
Touchpad doesn't work. Ethernet controllers, Multimedia Audio controller, PCI modem, Video controller and Video controller (VGA compatible) are not installed according to hardware properties. Do i nee
Yes- you need to go to Toshiba's website and download the drivers for your unit. The drivers for all of this hardware should be listed there for your model.
Apr 13, 2009 | Computers & Internet
Multi media audio controller pci simple communications contoller sm bus control video controller vga compatable all with yellow question mark against them
multi media audio controller
sm bus control
I Have A Service Tag No. but when i Write the Number He Is Not Working
i Need Your Help
Nov 03, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Video controller
If it's the drivers for the laptop, you can find them at Dell's support site. If it's the drivers for the monitor (some monitors need their own drivers in order to work) you can find them at the monitor manufacturer's site or driverguide.com
Jul 05, 2008 | Dell Inspiron E1405 Notebook
Screen gone wild
If your external video is working, most likely your VGA controller is good. Your laptop is using the same controller to control internal and external video. It could be two things that would cause your problem:
1. LCD VGA cable that connect your LCD to the laptop
2. Bad LCD VGA connector on the board(cold soldered joints)
3. BAD LCD panel
Any of the following repairs will require disassembling of your laptop.
Regards
May 27, 2008 | Acer Aspire 4520-5582 Notebook
External VGA controller
The VGA adapter is only for use with Pocket Power Point: 1. Open a PowerPoint presentation. 2. Go to the View menu and select External VGA on the View Show On drop down menu. 3. To make the presentation display automatically, under Advance Slide choose Automatic and enter in the amount of time in seconds between slides. 4. Say OK to that screen, then go to the View menu again and select View Show and now the presentation should display on the VGA monitor in 640x480 and 256 colors.
Sep 14, 2005 | NEC MobilePro 750
Foxconn P4M800P7MA-RS2 Motherboard Logo
113 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
