Question about Fujitsu Siemens Computers & Internet
Juice on pi-1536 keyboard and touchpad
Keyboard is changed and notebook is working now, but touchpad doesn't work OK.i'd like to clean it, but i don't know how to remove upper cover
    Problem Solver:
  • 14 Answers
Juice on keyboard ?? Disconnect ALL power immediately!! Then, remove keyboard, run under quite hot tap water, then immediatey submerge keyboard in isopropyl alcohol in a shallow tray, place in a beach towel & with washing machine water OFF, spin the unit in towel, allow 24 hrs to dry in sun, reinstall. It works.... If LAPTOP got drenched, stand on side, with screen open, dry thoroughly 2 days, pray a lot,
Posted on Jun 21, 2009
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Fn-F9 not working
From the description the laptop keyboard needs changing, check www.ebay.com Type make and model of laptop, refine search to keyboard, but I would use external keyboard first to verify. To disable the touchpad go into device manager, check list and click on the left box, right click and highlight disable, press ok or apply.
Jun 23, 2012 | Toshiba L355-S7905 (PSLD8U0Q3033) PC...
Hello! After I changed the keyboard (my daughter threw some water over it), the touchpad stopped working. I mention that the touchpad worked after the water was thrown on the keyboard. What can I do? Thank...
first felt sory abou that...
try to dry inside your touchpad it can make water can make short on touchpad. for keyboard the dirty makes your keyboard mallfungtion
Jan 14, 2011 | ASUS Eee PC 900 PC Notebook
Keyboard not work
my first suggestion is to reinstall you keyboard drivers
insert your windows cd and go to control panel-system-devicemanager-and locate your keyboard/touchpad.
right click and open, reinstall driver and point the install to the windows disk.
reinstall the keyboard drivers and see if that corrects your problem
If that doesn;t work, you may need to do a fresh OS install to get everthing back in order.
go to this link for driver downloads
if this helps you please leave a vote in fixya
May 23, 2009 | Microsoft Windows XP Professional
Laptop keyboard not operational
If you replaced the keyboard with a Dell replacement 1501 keyboard and it still doesn’t work then yes the motherboard will probably have to be replaced. If your son spilled water on the laptop it could clear up after it completely dries. If it was juice, soft drink or sport drink the laptop could develop other issues. The syrup in these kinds of drinks don’t evaporate, they just remain there and accumulate foreign particles like dust, hair, dirt and eventually start to corrode electrical contacts like acid. Similar to the terminal posts on a car battery.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Apr 28, 2009 | Dell Inspiron 1501 Notebook
Keyboard doesnt function properly
It is possible that the keyboard matrix is shorted so when you use the external kbd it still gets the same errors. See if you can disable the main kbd in bios and if that solves the problem. You could also try removing the main kbd and see what that does. Otherwise you probably have a motherboard problem. The touchpads are usually pretty tough to liquids - check the cable on that.
Jon
Apr 13, 2009 | Dell Vostro 1000 Notebook
Keyboard spill
First thing you want to do is keep it from getting worse. Open the laptop all the way up and set it keyboard face down on a soft towel to wick away any juice. Once that is dry you can remove the keyboard (or have someone help you) by typing in you model number and "keyboard replacement" in Google - you are bound to find a tutorial. Most of the time you will gently pry up the cover where the on/off switch and panel lights are (above the keyboard) and then remove a couple of screws and lift the keyboard out. Be very careful with the ribbon cable(s) that connect to the motherboard and make sure you have grounded your static electricity (not usu. a problem in the south). Also check that no juice has gone beneath the kbd - if so best to take to a shop for cleaning. Many times you can rinse the keyboard and let it dry and it will work. If not you can get a cheap replacement on eBay.
Jon
Apr 12, 2009 | HP Pavilion TX1000Z 12.1 NOTEBOOK LAPTOP...
Acer aspire 1302 keyboard, touchpad, usb doesn t work
check with your keyboard works in Bios
please check with external key board
if it works ,then need to change the key pad
Mar 14, 2009 | Computers & Internet
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
Touchpad dead, keyboard erratic
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc.
Both touchpad and keyboard will be reinstalled and then ready to use again as it should be back to normal
Sep 10, 2008 | Acer TravelMate 4001WLCi PC Notebook
Computers & Internet Logo
503 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
