Question about Dishwashers
I need to get the drain plug out of the garbage disposal so i can hook up my dishwasher to drain. can this be done without disassembling the disposal. can i knock the plug out into the disposal
  • 5,911 Answers
Take a flat blade screwdriver and insert it into the drain port that you connect the dishwasher drain line to. Take a hammer and tap the screwdriver until the plug pops loose inside the disposal. Now, reach down inside the disposal and retrieve the plug. You should not have to disassemble the disposal to do this. I hope this answers you're question.
Posted on Jun 21, 2009
Ultra wash ll. Why isn't it draining after it's done?
Did you break out the plug in the garbage disposer so water can go thru it .
Jul 26, 2015 | Kenmore Dishwashers
Replaced disposal and now dishwasher isnt draining
It sounds like you've done everything fine. I would disconnect the dishwasher drain line from the disposal, have a bucket ready and see if it will drain. It's possible that there is a plug or something else left in the disposal opening that is blocking the water. If the dishwasher won't drain with the hose off of the disposal, there is a problem with the dishwasher that has nothing to do with your disposal installation. Hope this helps and good luck!
Mar 12, 2010 | Dishwashers
Dishwasher will not drain totally after it has finished the cycle. I recently had a new garbage disposal installe and every since then the dishwasher will not drain. Is it something to maybe do with the...
disposal has a plug in it where the drain line from d/w hooks up remove drain line from disposer and stick a screwdriver in hole to remove plug remove plug from inside disposer with a pair of needle nose pliers that should take of it
Oct 26, 2009 | Dishwashers
Model: DU1345XTVB Whirlpool Dishwasher recently installed will not drain?
If you have it hooked up to a garbage disposal you may have forgotten to remove the knockout plug in the disposal,It is made to use with or without a dishwasher so they plug the drain hole and you have to knock it out.
Aug 12, 2009 | Dishwashers
Can i connect my Hoover HD73M Dishwasher to a cold feed?
First off, you need a hot water feed line for your dishwasher, not cold water
Secondly, if you have a garbage disposal installed on your sink you can connect the dishwasher drain hose to the side port on the garbage disposal. That's what that little port is for anyway. If you do have a garbage disposal and hook the dishwasher hose to it then make sure you take a hammer and screw driver and knock out the little plastic plug that's inside the garbage disposal port before hooking up the hose to it, if you don't you'll flood your kitchen.
If you don't have a garbage disposal on your sink, then you're going to have to replace a piece of your sink's drain piping with a wye (Y) tailpiece. The tailpiece has a small branch that comes off it to where you can connect the dishwasher drain hose.
Regardless of which way you hook up the drainage and water lines, make sure you test out the work you did by running the dishwasher and keeping an eye on it. I can't tell you the number of times i've seen people hook up stuff like this and not test it and then when they go to use the dishwasher it floods the kitchen..... usually when people are sleeping at night. Test your work.
Aug 01, 2009 | Hoover 24 in. HD73M Free-standing...
Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
May 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 | Dishwashers
Whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Jan 13, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 | Dishwashers
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
135 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
