Question about Tyco Rc Turbo Pro Wheelie Cycle
Gear in back tire stripped
Where to Fix?
The rear wheel does not spin with motor running
Posted on Aug 24, 2009
Front tire assembly gear stripped...any way to fix.
with no make ,model we can not assist
Nov 23, 2015 | Cars & Trucks
My ( 2008 Kawasaki Kx 100 ) kick-starter won't move down.. I tried Push Starting It and It's Seem To Lick The Back Tire... The GearBox Seem The Be Fine it's goes in neutral &' too gears 1-6 ... Also Moves...
Think you have simply frozen your piston from lack of proper fuel and 2 stroke oul mixture. Bike will move in neutral and with the clutch in, just won't kick or bumpstart ! Time for a top end rebuild my friend...good luck !
May 18, 2014 | Motorcycles
Polaris 325 magnum
It sounds like it could possibly be the ring gear in the rear differential. (Where the drive shaft enters the diff.) If the ring gear gets stripped the drive shaft will turn but it's not transferring that power to the rear axle. Lift the rear end off the ground and spin the rear wheel by hand. Listen for a clicking sound at the rear differential. If it is clicking then I would bet the ring gear is stripped.
Nov 17, 2017 | Polaris ATV
Yamaha warrior is stuck in 3rd gear nad rear end is locked up and there is play in the shift lever but wont click into any gear
sounds like gear box needs stripping and check allcogs and selecter forks etc for wear or damage! happened to me on a yamaha rd 200 ! P...
Jan 02, 2014 | Yamaha RD 350 Motorcycles
What makes your tires not move when u turn your steering wheel on a 1999 chrysler 300 m
gear stripped at steering wheel to shaft, stripped steering gear at the rack n pinion. Inspect steering shaft and connections.
CHeck here first:
I doubt its here, but if not anywhere else, check here:
Dec 08, 2013 | 1999 Chrysler 300M
Pentair front wheels not turning
make sure the inside of the wheels arent stripped they are gears if loose take apart adjust out so they touch the other gear that should fix that if gears are stripped you can change the front wheels to the back
Oct 19, 2013 | Pentair White/Gray Legend Platinum...
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
Steering gear/rack & pinion needs to be repaired or replaced
Take the vehicle to an alignment shop take employees ASE Technicians. They will remove the stripped bolt and get you safely going again. Its hard to give you a price so I'm gonna go for the worse case scenario and you take it from there. New rack about $350,Labor including wheel alignment and balancing about $400. Total about $750. Now if your tires are bad they probably will not do alignment so figure about $100 for each new tire. Add that to $750. Remember this is the worse case.
Apr 22, 2010 | 2001 Hyundai XG300
Tyco Rc Turbo Pro Wheelie Cycle Logo
219 people viewed this question
Top Tyco Toys Experts
john h
ray gallant
Robert Reed
Level 1 Expert
Are you a Tyco Toy Expert? Answer questions, earn points and help others
