Question about Electrolux Washing Machines
Joint sealant for drum bearing, how to use, zanussi zwf1020w
  • 3,600 Answers
Are you talking about the putty like matieral? if so it goes against the drum and the beagin but need more info.
Posted on Jun 21, 2009
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
Jan 11, 2010 | Zanussi FLA1101W Front Load Washer
Zanussi 1400 jet model nowjd1457w ball bearings have come out
If ball bearings have come out, then there are only 2 possible places they could have come from.
1- The motor bearings.
2- the main drum bearings.
In both cases, it is a expensive fault to rectify.
To check, remove drive belt, and spin drum by hand, this should help you to tell if it is the main bearings or the motor.
Dec 16, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Zanussi IZ12 bearings gone & plastic fragments in drum
    Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
    Feb 15, 2009 | Zanussi IZ12 Front Load Washer
    Removing/replacing main drum bearing on a zanussi WDT1085
    Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
    It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
    Good luck if you decide to proceed.
    Plz rate my suggestions.
    .Thanks.
    Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
    Zanussi aquacycle 1200
    May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
    Slim Jim
    Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
    Washer will not work
    Possible drain fault, check filter. Regards Advisor
    Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
    Washing Machines Logo
    73 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
