Question about Kitchen Ranges
How do you open the smooth top, on a Maytag range?
I have one triple coil, underneath my MER5775RAB smooth top range, which instead of 3 is only heating on 2 coils. I am handy on older ranges where you just lift up the top, but never did this on any smooth top type models. Any Advice? I can't find a DIY manual to tell me this online. Your experience would be appreciated, as I would like to learn this, if possible. I am carefull to disconnect electric cords, and have replaced coils before, will no problems.
  • 1 more comment
  • webwalsh Nov 07, 2007
    attach the pdf if you like to the email address of Thanks
    Hopefully it will show me more about this smoothtop's metal underneath with screws that need removing next, to reach the coils. Is there a disconnection at the back of the smoothtop before I unscrew this metal plate? Thanks Bob
  • webwalsh Nov 09, 2007
    Try sending it one more time. I made adjustments to help raise less confusion, with my email protection just for you !
    I really appreciate all your patience and assistance Mike!
    I have received the Pdf and will look it over, in the next few days. Thanks Mike
  • 290 Answers
There will be 2 or 3 screws under the front edge of the top. Take them out and top will hinge up similar to the older models.
Unplugg the range before touching any wires. There is voltage on the thermal limiter on the element even when the switch is off.
Once you have access to the element you can check for power and continuity just like on an older range.
Post back with any questions. I will see if I have a manual on pdf.
Posted on Nov 04, 2007
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Nov 04, 2007
    I have a manual on the MER6770 in pdf which should be the same basic range as yours. If you will give me an email address I will send it to you.
  • Michael  Lindley
    Michael Lindley Nov 07, 2007
    There should be a connection at the rear after you raise the top. I think you will find it isn't as complicated as you are expecting. I will send the manual.
  • Michael  Lindley
    Michael Lindley Nov 08, 2007
    I hope you recieved the manual. I recieved a response to verify the email and clicked on the link. Most of the message was encrypted so I am not sure if I did what I was supposed to do.
How do i open the top to clean under the burners
Normally it's easy. Just lift the range top from the front andtheir should be a lever to pop up and support the range top while you clean. :)
Dec 02, 2015 | Maytag Kitchen Ranges
Can you replace a Maytag smooth top on a slide in range?
Yes it is replaceable but expensive. Approx $334 plus shipping at sears. The glass top unbolts at the front then lifts off at rear but all the burners must be removed and mounted to the new top.
May 31, 2014 | Maytag MER5775Q Electric Kitchen Range
How do I remove the top on a Maytag range
Unplug the range from power.
Open the oven door. Look on the right and left sides of the oven frame just below the top. Remove the 2 screws. Pull the top forward. Remove the wiring harness connector at the back.Lift the top up and off. Set the top aside.
Nov 11, 2009 | Maytag MER5775Q Electric Kitchen Range
Whirlpool Electric Cook top Coil
there may be 2 screws on the rear/behind of the cooker top or on the front underneath the top when top oven door is open.
Sep 30, 2009 | Hotpoint RGB745 Gas Kitchen Range
Need to know the BTUs on stovetop Burners
BTU ratings are usually the Model Number plate which is located in one of three places for Maytag:
1-Underneath burner top if top lifts up easily
2-On left lower front edge of frame with door open
3-Left edge of front oven frame with drawer open
Aug 23, 2009 | Kitchen Ranges
Leaky Maytag
most likely. the tub seal is bad. mine did the same thing. had to replace the seal. part is called a triple lip seal. not hard but not a walk in the park either.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Single element in 3-way burner won't work
Hey Janice,
Sorry to hear this.. but, here is a site that will answer your question more completely.. ( I think this is a complete replacement job).. and if your are mechanically inclined, you might be able to do it yourself... good luck,,
as far as costs... that's such a wide range of "prices per hour or by the job", it would not be feasible to put a $$$ figure on here..
Jun 19, 2017 | Maytag MES5775BAF / MES5775BAN /...
Replacing smooth top
You said, you broke the top of my stove - how do i go about replacing it? I have a maytag smooth top stove I don't have the model number its torn off the stove was here when I moved in and now its broken and has a big crack in it how do I get a replacement please help.
This is more than likely your ranges model # MER6772 Gemini Electric Kitchen Range
Maytag will be able to replace the top once they come out!
Below is the info and help you asked for!
Thank You , Huuum
Please remember to leave a solved rating before you leave!!
Here is what you asked for!
Call the dealer from whom your appliance was purchased or call Maytag Appliances
Sales Company, Maytag Customer Assistance at 1-888-462-9824, USA to locate
an authorized servicer.
Be sure to retain proof of purchase to verify warranty status. Refer to WARRANTY
for further information on owner’s responsibilities for warranty service.
If the dealer or service company cannot resolve the problem, write to Maytag
Appliances Sales Company, Attn: CAIR® Center, P.O. Box 2370, Cleveland, TN
37320-2370, or call 1-888-4Maytag for PriorityOne Service (1-888-462-9824).
U.S. customers using TTY for deaf, hearing impaired or speech impaired, call
NOTE: When writing
Oct 14, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven or smooth top will not turn on. breakers are good and it is plugged in.
Unplug the range. Wait a few minutes, then plug the unit back in.  Reset the clock per your user manual. A pdf copy of your manual may be available on line at the Magic Chef site or the Maytag site, since Maytag has or had a similar model.
Dec 04, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
708 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
