Question about Kenmore 53701 Dehumidifier
The fan runs constantly. The compressor starts,
The fan runs constantly. The compressor starts, hums about 2-3 seconds than kicks off. It does this right from initial start up, so it is not frosted up. When auto airconditioner compressors do this they are usually low on coolant. Can this be repaired or is a new one in order. The unit is only three years old.
  • 43 Answers
Check the compressor run capacitor first.
Posted on Jun 23, 2009
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
I have H. Bay model HB40F dehumidifier. It does not seem to ever actually start the compressor. There is a plastic box on the side of the compressor that contains a couple of coily looking things. It...
It is probably the start device(the coil looking things), as long as you don't hear the compressor humming. A loud hum is a lock compressor and the cost would be far greater than a new unit.
Jun 17, 2011 | Soleus Dehumidifiers
Fan runs fine, but compressor doesn't start-it hums for a few seconds, then kicks out. GE AHG40LAG2 serial AZ202478 dom 1/00 R12
The compressor has gone bad and will not start... what you he3ar is the compressor trying to start....it will probably cost you more to replace that compressor then buying a new unit...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | GE AHG40LA Dehumidifier
I just bought a Danby Dehumidifier model: DDR6009REE The fan runs constantly even when the humidity setting is reached and the compressor is off. has anyone patched the power for the fan by putting...
All new generation dehumidifiers are designed to have the fans run all the time and the compressor comes on when the relitive humidity rises above the setting that you have chosen. I spoke with the company and asked them why this is so, and they told me that it is more energy efficient to have the machine on all the time so that when the compressor kicks in there is a small draw on electricity.
Apparently when the old dehumidifiers came on it was the compressor that turned on immediately, and the fan, and this caused a very high current draw. The new design has the fan on all the time and this helps to circulate the air evenly around the area being dehumidified - thus more efficient overall coverage.
I understood their explanation, but still do not like this new method of operation.
Jun 26, 2010 | Danby DDR6009REE Dehumidifier
The Kenmore 106.955501 dehumidifier works well when first started, coils get cold quickly, fan runs, air moves well. after 1 hr when the compressor needs to kick back on, the lights on that circuit dim and...
The compressor will not start when it is hot or it is no longer bleeding the pressure off fast enough on the high side of the refrigeration system and it cannot start under the load. The start relay and capacitor could also be bad...that would give the same symptoms...
heatman101
May 01, 2010 | Kenmore 54501 Dehumidifier
The compressor will not kick in It will start up and try but will not run Fan continues to operate Almost sounds like the compressor motor is binding trys for about 2-3 seconds and shuts off fan will...
The condition you describe usually indicates that either the compressor is working too hard and drawing too much current or the start relay is gone bad. The noises that you hear may just be a safety shut-off within the relay. A good place to start is changing start relay for the factory recommended one. you will have to access the compressor compartment to see this.
If the standard relay does not correct the problem, there is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your dehumidifier first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system or a faulty compressor. Outside of this may require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a refrigerant leak.
Check your owners manual before making any repairs or modifications to your refrigerator. And there may be an extended warranty on the sealed system and compressor if needed.
Aug 06, 2008 | Maytag M7DH45B2A Dehumidifier
Compressor does not start
some of these units have a 5 year compressor warranty on them including labor worth calling sears and seeing if it does have the 5 year on the sealed system
Apr 09, 2008 | Kenmore 53509 Dehumidifier
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Kenmore 53701 Dehumidifier Logo
760 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
