Question about RCA D61W20 61" Rear Projection Television
TV does not turn on model RCA D61W20B
When I turn on the TV the green power lamp illuminates then I hear a sizzling sound. The TV does not turn on.
RCA D61W20B
  • Anonymous Mar 18, 2014
    WHERE DO I GET THE LAMP FOR THE RCA
    Problem Solver:
  • 6 Answers
First check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Posted on Jun 21, 2009
My RCA HDTV model # D61W20B will come on make a short squeal and turn off and will repeat this over and over. What is the problem how can I fix it ?
That set uses a color wheel on a high speed motor and a ballast to power the lamp. It is hard to guess at this point what it is without further info.
Apr 20, 2015 | RCA Televison & Video
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
Will not stay on
It sounds like it could be your power supply board. You can get one from tristatemodule or shopjimmy. I personally use tristate its always cheaper and Ive had good luck with them but shopjimmy is pretty good too.
May 13, 2013 | RCA D52W23 52" HDTV CRT TV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
TV Will Not Turn On
The set has a 3 strikes and your out (not a joke--what RCA calls this).
It really means a short somewhere, almost anywhere--two things: when you try to turn it on do you hear a faint arc or sound like something sizzles?
Have you done a visual inspection of the main boards looking for anything clearly burnt?
These are not easy sets to work on and frankly I am the only one in our shop who will even attempt to fix one.
Apr 14, 2012 | Televison & Video
I have a RCA 61" d61w20b, i can turn on the tv and the sound is good but the picture is not right it bows and distorts the picture, it shows the picture in three colors green, red, and blue could it be the...
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Here’s a link to a decent video that will give you an idea of what is needed to fix it: http://www.youtube.com/watch?v=S6Wa8FvSz-s
Aug 30, 2010 | RCA D61W20 61" Rear Projection Television
Will not turn on RCA model D61W20B
the tv won't turn on with the remote or with the power button
Jan 30, 2010 | Televison & Video
TV Does not Turn on
it sounds like the power transformer maybe out on the set.it supplies power to the whole set and it sounds like it only getting partial power.
Jan 17, 2009 | Panasonic PT-52LCX66 Projection Television
RCA D61W20B
On the Deflection board CK capacitors cp150,cp114 cp120,If cp 150 is puffed up on top it is bad so replace all 3 capacitors 2200uf 16 use 25v and Two left are 220uf 35v Resolder pinns on flyback Transfomer and when re hooking board back up make sure you have second ribbon connector in good. Board next to Deflection is the SSB it has turners on it where you hook cable.
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
420 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
