Question about Samsung AW0603B Air Conditioner
Ac not colling
I have ice all on lines and compressor please help and want to do it myself
    Sergeant:
  • 199 Answers
Your ac is freezing, not enough freon, refill
Posted on Jun 21, 2009
07 Nissan Titan blows cold when ac on then after an hour it so it blows warm when I turn the ac off for approx 5 minutes and turn on the it's cold again. On long trips in AZ ac is a must. Help!?
When it starts runing warm check to see if the compressor clutch is engaged and turning the compressor.. Check for lines freezing up.. look for ice where the line(Pipe) GOES THROUGH THE FIREWALL into the evap housing. There is a relay that turns the compressor clutch off at certain times (to save fuel) .. possibly this is malfunctioning.
Jul 20, 2014 | Cars & Trucks
ED2khaxvq01 not cooling ref and freezer
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Oct 10, 2012 | Whirlpool Refrigerators
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
Please i have serviced the ac and it still not colling why
Sounds like maybe your compressor is not running... is the fan running by the compressor running?? if not then you have a starting problem It would be a bad run relay and start capacitor
Apr 02, 2011 | Refrigerators
When ac compressor engauges you can notice strain on engine . Shortly after that a line came off condenser with a loud bang.The line that broke goes from compressor to condensor. Now compressor is noisy....
The head pressure got too high on the ac system,when you have the ac compressor replaced,and it`s components,make sure the condenser is flushed out good,and that the cooling fans are working with the ac,they need to come on with the ac,if this was at all helpful,please rate,thank you.
Jul 26, 2010 | 2001 Ford Taurus
My window ac is not providing cooling. The compressors runs but it doesnt colles the cooling coil. The regerent is also charged
the start capacitor is either defective or if the compressor has a ptc overload relay,this could be the problem then
May 20, 2010 | Kitchen Ranges
My AC NO COLLING
if your sayin the unit isnt cooling then you need to see if it blows any air at all if so and its just warm or regular air then fist check your run capacitor to see if thats bad and at the same time put your hand on the top of compressor to see if thats running it should feel like a humm if not running copressor is probably bad if it is running then most likely its low on freon and if thats the case you have a freon leak some where in system and the new freon laws these days are requiring the a/c company to find and fix leak before adding freon .some companies will just fill it and the same problem will accur soon again.send back more info ,like is unit blowin air is compressor running and i can pinpoint problem easier thanks and let me know the outcome
Sep 29, 2009 | Bryant 462AJC021BA Air Conditioner
Ice maker not working and freezer temp only -4
it seems tht the problem is with the compressor of the refrigerator.
sometimes it happens that the "gas" in the compressor leakes off and ,tht gas is responsibale for the colling of the refrigerator.
so,either you can go for refilling of gas
or u can buy new compresssor of same rating as refregerator have.
my personla recommendation is to go for new compressor bcoz most of the time it happened to me that the customes complain abt the temperatures and some complain abt the leakage od gas again.
so,best option is to go for new compressor.
in case u hav any problem furthur just write me on my email -anshlittle011@gmail.com
Jul 06, 2009 | Liebherr European Right Hinge Fully...
Air conditioning wont turn on.
There should be a drain tube through your fiewall for condensation from the AC. It must be plugged.
May 20, 2009 | 2005 Toyota Tacoma
Ac fulley charge not getting coole
your compressor clutch might be shot in wich case the system although charged will not circulate the freeon.
Mar 01, 2009 | 1995 Suzuki Sidekick
Samsung AW0603B Air Conditioner Logo
265 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
