Computer frequencys My computer frequency is higher than it should be and I can't fix it from a normal start how do I fix this problem??
  • 121 Answers
Hii
If it is running at a higher frequency than its normal frequency then you dnot need to worry about it.For more free technical support you can visit==http://robs-tech.blogspot.com/2009/06/looking-for-free-technical-support.html
Posted on Jun 21, 2009
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
Monitor flickers and faint bands scroll down the
could be fixed by ajdusting the refresh rate....
you could try this (xp pro sp2)
please rate if useful, good luck
Open Display in Control Panel.
On the Settings tab, click Advanced.
On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Oct 27, 2009 | HP w1907 LCD Monitor
I have waves on my screen, what do I need to do to get rid of them?
you don't say whether your monitor is crt/tft....
either type the problem is likely to be refresh rate of the monitor...
try this... (xp pro sp2)
  1. Open Display in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate
  • To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
good luck, rate if useful please
Oct 27, 2009 | Computers & Internet
Out of frequency set resolution or see monitor
If you are getting a splash screen (COMPAQ) then video goes black, you can try this. Boot system in Enable VGA mode from the F8 menu and see if you get to the desktop. If you do, you can then go to display properties and adjust the resolution to the Optimal for the monitor.
If you do not get a splash screen, check you cable connections and ensure the Video cable is properly seated and no bent pins. If issue is occurring after the system was moved, also ensure that the correct video adapter connection is being used on the tower, as there may be 2
Oct 04, 2009 | Compaq 7500 17" CRT Monitor
"out of frequency range" message nothing works
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Oct 02, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
Hp 2009m screen goes black - no signal
change frequency setting to 60hz from the option of graphic setting using another monitor then agin connect your problematic monitor.
step1.open properties on desktop using right mouse click.
step 2.goto last tab (setting)
step3.goto advance optinion
step 4.goto third tab(monitor)
and there is option of frequency change it to 60hz save it and press enter.
now shutdown computer then connect your screen goes monitor check it.hope it works.
when screen black its mean the range of signal frequency higher then compatible frequency.
Aug 01, 2009 | Computers & Internet
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
Playback of sound
There are internal crystals on the sound card that determine frequency.
It's possible that it is "vibrating at a higher frequency can multiplying the speed...
Try a standard MP3 to see if this applies to all sounds....
Check your CPU clock rate to make sure that it hasn't been adjusted (To soup up the PC speed)
Try an alternate sound card if one is available.
Feb 10, 2008 | Intel Pentium 4, 2.4 GHz Pentium 4-M 705...
The dead screen
Thats it..its a frequency mismatch..Along with the size of the memory you have something called frequency(133Mhz, 333Mhz) etc., if these frequencies of both rams are not matching your computer is not starting up..try to get a ram of the same frequency..
Nov 18, 2007 | ASUS P5GD1-VM Motherboard
Monitor installtion
Hi Robin,
Hope this instruction well do solve like I met some problem like this. Try to reset the monitors setting manually in OSD (on screen display) mode. Look for frequency settings start at lower and have test it all. Respectively try to configure the video card frequency settings at Operating System GUID (Graphics user interface display) video card setting properties. Start from lower frequency and notice the each changes. When perfectly proportionate select Apply settings.
Best regards,
Rosener Guyano
Nov 13, 2007 | ASUS VW192S Monitor
Computers & Internet Logo
Alun Cox
David Payne
David Payne
