RCA RS2664 Shelf System Logo
Posted on Jun 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just need a manual for this device. It works
I just need a manual for this device. It works fine, except I don't know what some of the buttons are for. I inherited it from an elderly friend who must have lost the manual.
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Jun 21, 2009
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
23692
Points
259
I have a Zanussi ZJD 12192 and everything appears to work except it simply won’t start no matter what I do. All the buttons and dials work fine except the start/pause button. Any idea? Thanks
Before it will start the brain needs to know the door is closed and locked. The door catch is connected to the brain - perhaps they are no longer communicating...
CHANGED BATTERY IN MY 2009 HYUNDAI SONATA 2.4 GLS. AFTER CHANGING ALL FUNTIONS WERE WORKNG AGAIN EXCEPT OVERHEAD BLUETOOTH, LIGHTS ON BLUETOOTH COME ON BUT WHEN I PRESS THE BUTTON TO CALL SOMEONE IT WANT...
You may need to repeat the pairing process for your car and BT device as you did when you first got the car / device. Check your manual for the procedure.
1helpful
The guitar hero Wireless don't want to work at all I hit the Wireless button on my Xbox but it doesn't pick up the signal
I don`t own a exbox however many programs need to recognize and the function must be set to except the external device and make sure the correct batteries are being used some equipment wont work with certain types such as my mouse that wouldn`t work with a camera AA rechargeable battery but did work with a plain ever ready rechargeable.
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
1helpful
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Unknown pattern has my xoom locked how can i get it to except a new pattern
If you don't know the pattern, you will need to restore the xoom to factory settings. This will delete everything on the device.
While powering on the device you need to hold the power button and either the up volume or down volume (usually its the up). This will load a menu and select restore factory defaults.
Comment back if you need more assistance.
I don't know which button to press for it to print. I have no instructions manual
You do not have to use the printer buttons to get a print except power on button after connecting to mains supply & usb/parallel cable to PC. After installing the driver in your PC, it will show in print menu of respective application. Nowadays the manual in pdf format is available in the driver CD/DVD itself.
sonsunny
Need a manual
I have downloaded the manual from Hyundai website en_man_monitor_lseries_l52s.zip
Acer e lock activated??????????????
I've researched this and it appears simply uninstalling the elock software may resolve it - if this is not a feature you require.
Since it is an Acer specific issue you may contact the manufacturer for assistance while it is under warranty.
Machine does not stop after dispensing two shots of espresso
That kind of machine is pretty well engineered!Very solid and work on a basic deal.The problem could be just the simple on/off button.
The pump is controlled by the button and if the button don`t stop the machine still understanding you need more until you close the circuit.Sometimes coukld be also a loose wire.
In some way you are lucky because that machine have not electronic board so...less part.....less problem
Don`t forget to rate your experiene
Fabio
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
