Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
I have a weedeater barracuda sv30 blower had it for years worked great. Today after looking at it and not starting today and hard to keep running 2 weeks ago I looking in the gas tank and pulled the fuel line out with the filter attached. I would assume this might be the problem. Will I need to get a new fuel tank assembly? I felt around inside and can't feel where it connects
  • vette84 Jul 10, 2009
    Hi Jim This weedeater blower does not have a primer bulb just choke. The in tank line and filter are not connected just loose I pulled it out and stuck my finger in but could not feel where it would go I also looked at the fuel lines from the carb to the tank for a location and still can't feel anything. Some one told me this unit had a nipple inside the tank that the in tank line hooked up, some one else told me the was a grommet to hook the line into. I can't feel or see anything. any ideas thanks Doug
  • 1,041 Answers
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
Manual for barracuda sv22 gas blower vac
User Manuals
Just put in your model and download from this site.
May 21, 2012 | Weedeater Garden
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
PB251 runs 1/2 speed. Can't get full
several months ago I worked on a friends blower same thing you did and still could not get the right rps pulling my hair out i started to take it apart again this time when I started it i noticed some fuel popping back out of the carb and just for the heck of it i turned it over a checked out the exhaust bam there it was the exhaust port was clogged with carbon i took a small screwdriver cleaned out that exhaust port and it was like new hope this is your problem to
Apr 15, 2010 | ECHO, Inc. PB-251C Handheld Blower
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Weedeater gas edger won't start!!!!!!!!!
yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
I have a weedeater leaf blower that will start when I put gas in the caberator but will not run otherwise
sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Jun 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
My sv-30 blower will not continue running.
Have this problem currently with my WeedEater SV30, and I suspect the filter fuel line has rotted off where it passes into the tank. Had exactly this problem with my cheepy trimmer and was able to replace the fuel line. Hopefully I can do the same with my SV30 blower. Seems like the gas line material does not like the ethenol in today's gasoline...
Mar 28, 2009 | Garden
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
1,850 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
