Question about HP Compaq Presario V6000T PC Notebook
Copying file problem
Whenever i copy or cut file from one place to another place system not responded. i also have defragmented the local disks.
  • merarangdeba Jun 21, 2009
    presario v6316tu
    512mb ram , 80 gb hard disk
    1.73ghz
Wat is ur system configuration?
moreover i would suggest to go for a system format.
Posted on Jun 21, 2009
  • Anonymous Jun 21, 2009
    I would suggest u to upgrade ur RAM and make it 1 GB. ur problem will be resolved then.
A software to clean up my computer
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Lloyd Clement.
There are many useful applications in Microsoft Windows that will clean up your computer and make your computer faster and more responsive.
They are the following:
1.) Microsoft Windows file defragmentator refered to as a hard drive defrag. It simply sorts out all your files on your hard drive and places them in order for better reading performance.
To Perform Defrag: Click Start, then All programs, then Accessories, then System tools, then Disk Defragmentater. Once opened click defragment hard drive usually C: drive
2.) Microsoft Scan disk. The application scans your hard drive for errors, bad clusters or segments. If it flags a cluster as bad it simply copies your information from that cluster and moves it to the next available good sector.
To perform scan disk: Double click My Computer, then right click your hard drive and select properties, Now click the Tools tab, under the heading for Error Checking click Check now.
You will noice the option to Defragment shown below the error checking option.
Those are the fundamental programs that will keep your computer system running well.
Take care!
Dec 26, 2011 | Computers & Internet
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
I have a toshiba laptop l45-s7409 when i copy a disk with toshiba disk creator or copy image the computer at the end of the copy gives me an error message 0602772628031105 i tried updates in the website...
There is a chance of Bad sector, Try to defragment first... it can fix any simple bad sector problems (from manage) or from all programs>accessories>system tools>disk defragmenter (in windows xp), in win7 search for "defragment"
Aug 27, 2011 | Toshiba Satellite Pro L300 Notebook
Unable to store job at printer
Your print buffer is full in your hard drive.
Remove programs you don't use
Defrag the Hard Drive
Delete Temporary files in System Tools
Jun 20, 2010 | HP LaserJet 2420 Printer
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
For the last few days I've been experiencing problems . these problems are that when I try to copy/paste/move or delete/recycle it takes for ever in windows vista wheter if the file is big or small. can...
Could be a simple disk speed issue, try a defrag of the system disk (right-click and in tools select defrag).
Indexing of the disk can also affect performance, so you could try disabling that. Last thing I can think of is the location of the TEMP files, make sure it is not running full.
Apr 19, 2010 | Microsoft Windows Vista Home Premium...
Error Copying old c: drive w/Ghost 9
Do a disk defrag on the source drive. If that doesn't work, you may have a virus on your source drive and norton ghost is catching before getting on your destination drive.
Nov 24, 2009 | Symantec Norton Ghost 9.0 for PC
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hp Pavilion a1620n, XP Edition. I Can't defrag my recovery drive.
Unfortunately you will need to do exactly what it states, which is free up some space. Defragging a drive requires there to be an ample amount of "swap space" available so that it can move files into that 15% of space while it rearragnes the placement of other files and puts them back in an order which will provide faster access to the files after the defrag is complete. being that it is your D: drive, can't you just move some files to your C: drive to make enough space for the defrag??
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | HP Pavilion a1620n (RC655AA) PC Desktop
HP Compaq Presario V6000T PC Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
