Question about RCA HD52W59 HDTV Projection Television
Power on trouble
When i plug in the TV and press power the tv makes a whistle sound and powers off on its own and repeats that same problem 3 times.
  • RCA Master
  • 8,617 Answers
Most likely the flyback or HV splitter
Posted on Jun 21, 2009
Won't power on
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Jul 19, 2013 | Philips 47PFL7422D/37 Television
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Whistling sound
This tv whistling sound are causes by a high voltage currents flow from it is tv power supply board it self not functions properly anymore.That the board where the power a/c cord plug into it.Those high voltages tranformers have gaps in it solders joints and now it not letting high voltages currents flow smoothly anymore,that where the whistling sound came from.Tries take the tv aparts,tries to put some kind harden or supper glues to all those high voltages tranformers,might help or soften the whistling sound alot.If that did not help all or alot.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 28, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Television won't power up
It sounds like the high voltage circuit got damp and arced. This arc caused the horizontal output transistor to short.
You might try replacing the output transistor if you're experienced in this type of repair. If not then you need to take it to a repair shop.
The "whistle " you're hearing is the power supply indicating that it has a short on its load. When the power supply has an over load (short) its frequency drops down when your ear can hear it oscillating. This type of power supply is a switching power supply normally operating a several thousand hz(cycles) which is out of range of human hearing.
Stargazer
Mar 15, 2008 | Televison & Video
Will not power on
this could be a number of probs. needs to be ck'd by a tv tech can usually be repaired for a few hundred bucks suggestions..audio ic,convergence ic,signal board or power module..note these parts are pricey so trouble shoot to correct part. John
Sep 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
RCA F31672ET No Power only a whining noise when plugged in Please help
Most likely you have a bad flyback transformer and shorted horizontal output transistor. The whistling sound that you hear is the power supply telling you that it has a short in one of the circuits it powers. Most likely the circuit mentioned above. Stargazer
Mar 06, 2007 | RCA F31672ET TV
RCA HD52W59 HDTV Projection Television Logo
125 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
