I love my printer but it came up with message indicating a paper jam. Is there an access panel in the back to remove the jam?
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
SOURCE: Paper jam on HP officejet 6500
Try This :
Connect the printer directly to the wall outlet ; not through any Power strip
Then Unplug the Power cable from the back of the printer
Keep on tapping the power cable for next 30 seconds
Plug in back the power cable;
Open the rear access door and you will get to see some rollers
Clean the rollers with a Lint free cloth Moistened with some distilled water
Try to do a copy if still it doesn works
With one hand press and hold down the (#) and the (6) button and with the other hand plug in back the power cable ; it will do a Semifull reset on the printer; This will take some time ; Follow the instruction on the screen;
If still it doesn't work then you need to contact HP ;
The toll free no. for HP would be : 1-800-474-6836
They will replace the printer for you free of cost (No Charge if the printer is in warranty i.e within 1 yr of purchase)
Still you may check the link below for further issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&lc=en&dlc=en&cc=us&lang=en&product=3795406
Regards Soumajit
SOURCE: HP psc 1310 - gave paper jam and print cartridge
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
This
is how to clear paper jammed in canon inkjet printer.
1.
Protect yourself from shock. Disconnect the power cord from the back
of the Canon Inkjet Printer. This is an important step when working
inside ANY electronic device.
2.
Unhinge the back access panel of the printer. It seems repetitive to
say this, but this door will be in the BACK of the printer.
3.
Look through the opened back panel and look for paper. Remove any
and all paper you find jammed there.
4.
Close the back access panel. Make sure that it latches into place
and looks the same way that it did before you opened it.
5.
Find the front or top access panel. This is the panel you would lift
to change ink cartridges. Open this access panel. If the carriage
that holds the ink cartridges moves, then you forgot to unplug the
printer, go back and do that now. Look for paper that may be jammed
in this area of the printer.
6.
Remove any paper you find jammed here. When pulling from the front
there will be resistance from the paper feeder. Pull slowly or the
paper will rip and create a more stressful problem.
7.
Close the front access panel. Make sure that it falls or latches
back in place. It should look the same way that it did before you
opened it.
8.
Plug the printer's power cord into the wall outlet, and attempt to
print again. If the printer prints the job,
then you have successfully removed the paper jam
