Question about Rowenta Power Duo Iron
Removing deposits on iron plate
How do i remove deposits from iron plate on rowenta duo power ion
  • Anonymous Mar 15, 2014
    iron sparked and when I removed the back plate the end the plug melted a piece of the plastic
    Novelist:
  • 158 Answers
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Posted on Jun 22, 2009
There is plastic burned to bottom of my iron. How do I remove it?
I use my oven cleaner and it completely removes the marks
Jan 18, 2011 | Rowenta Power Duo Iron
How do you remove Torq screws that have that annoying center pin?
You Have to buy a 'security' torque set. I bought a set of security bits with 50 different types that included the one needed for the Rowenta Power Duo. It was only $9.00 at my local Harbor Freight store.
Oct 24, 2010 | Rowenta Power Duo Iron
Sticky substance on iron plate
get some of the Rowenta remover, YOu put it on your sole plate when Iron is warm. I use an old facecloth, put some on the cloth, then drag the iron side ways or back and forth. Then a clean towel to clean, when it does nto remove, i put some directly on the iron, does a pretty great job.. keep up with the stuff. If you are using fusible things when you Iron, you set yourself up with sggrivation, but a teflon cloth from a quilt store or on line,.It is used for applique and works great.
Jan 12, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
I have a rowenta iron, and began to iron a tablecloth with gold embossing. Now it is stuck on the plate. How do I clean it?
Turn the iron back on, get a sheet of wax paper, iron back and forth on the wax paper it cleans all of the gold and grime off. Then take a Magic Eraser and clean the plate after it has cooled. Won't scratch your plate. Hope this works for you. I have done it often.
Dec 31, 2009 | Rowenta Power Duo Iron
Excessive white particles on work to be ironed
It may be hard water deposits on the iron from using steam mode especially if you use well water, use distilled or purified bottled water in the iron and it will prevent more of it from building up. you can remove what has built up using vinagar or other store hard water deposit removers on the outside and rinsing off well
Nov 08, 2009 | Rowenta Irons
Wont turn on
I agree.
It is probably a loose screw (if you shake the iron, you may hear it rattle).. The iron is most likely good, just needs a 5 minute repair.
If you want to do it, or find someone to do it:
1. UNPLUG the iron.
2. remove the 4 screws from the back end of the iron.
3. Open the back plastic plate.
4. There will be a wire with a loose screw; tighten it.
5. There may be a broken wire near the screw; if so, remove the eyelet that is on the screw. put the screw back on and wrap the broken wire end onto the screw and tighten.
6. Replace the back plate.
7. Plug back in and use for a few more years.
Hope this helps!
Sep 04, 2009 | Rowenta Power Duo Iron
The cord is worn out where it connects to the iron and sparks flew when using most recently...
you have a broken wire. unplug the iron, you should be able to remove the cover. you can repair the wiring or replace the chord.
Jul 27, 2009 | Rowenta Power Duo Iron
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Residue on iron plate
They sell cleaner for this. Or just use very fine steel wool #000 or #0000. Only use on a stainless steel iron, not one that has non-stick coating.
Sep 15, 2008 | Rowenta Power Duo Iron
I have a Rowenta Power Duo iron that just quit heating. Is there a place in Memphis, TN that can repair it?
This is the main information about your iron.
You can call them and they will help you to find the right place
Rowenta Inc.
196 Boston Avenue
Medford, MA 02155
Tel: (781) 396-0600
Monday-Friday
from 8am to 5:30pm (EST
Good Luck
Jun 17, 2008 | Rowenta Power Duo Iron
Rowenta Power Duo Iron Logo
374 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
