Question about HP Pavilion dv6000z Notebook
My HP dv6700 freezes up after I have signed on from the password window. It works find in the Safe Mode but will freeze up after a couple of minutes sitting idol or if I try to work on any program or on the internet.
  • 14 Answers
I would advise to bring up the task manager (right click on the Windows bar across the bottom of your screen and select task manager) then click on the Processes tab. From there you can see the percentage of the CPU being used and Memory being used. System Idle Process should be high for CPU usage, but if you have anything else that seems abnormally high, look up that process online and see if it's safe to kill it. You can also sort the CPU and Memory columns by clickingon the column at the top.
If a process is holding you up and not essential to Windows. You may want to kill the process and uninstall the program that the process belongs to.
Posted on Jun 21, 2009
My laptop hp pavillon dv6700 can't entering to the bios, the screen stay black or freezing
Sounds like the GPU requires reflow soldering. Sadly only for experienced BGA soldering station users.
Nov 27, 2013 | Gateway MT3705 Notebook
HP DV6700 Freezes.
its a common windows problem. there is a multitude of options to solve this. try start windows in safe mode and start a program. if that works go a restore point back. or reinstall windows. or get a newer version of windows. windows 7 or 8 are likely to perform better than windows xp - assuming it is windows xp you run. avoid vista like the plague
Dec 02, 2012 | Computers & Internet
My laptop freezes at hp screen with F10 to enter ROM Setup, so I hit F10, and after about 3 minutes a black screen appears with a blue screen saying drivelock multibay password in it. Sometimes it just...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after just after you switch On until you get Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Jul 30, 2011 | HP Compaq nc6220 Notebook
I have an HP Media Center PC running XP Pro SP3. A few months ago it began freezing up requiring that I pull the power plug to get back into Windows. Then it would just freeze again, usually within a few...
just unplug all external devices except ur keyboard and mouse and restart,if u still have the same problem try with last known good configuration,then also with safemode with networking, if u still have problem first of all ,in safe mode only basic required drivers are loaded,it could be a driver issue open devicemanger to chk that as well
Nov 20, 2009 | Microsoft Windows XP Professional
POWERS UP BUT THEN FREEZES AFTER ABOUT 4 MINUTES
Need to test and isolate where it exactly freezes? After dell logo, after windows logo or while inside windows? Now, if it only freezes inside windows try to turn off your windows updates and antivirus first and check if still freezes, if yes then try booting in safe mode, reboot system then keep tapping on f8 once dell logo appears. Check if laptop keeps freezing in safe mode. Please let me know.
Oct 01, 2009 | Dell LATITUDE C600 PIII 750MHZ 128MB 15GB...
PC freezes on boot-up
Try booting the thing in Safe Mode. Upon startup (after the Acer logo goes) press F8 several times. You will be offered a menu select Safe Mode (at the very top of the list). If the system reaches the desktop, you can repair your Windows. For the three fixes below you will need to go Start Menu>Run...
1) Write: fixmbr, and press ENTER.
2) Write: fixboot, and press ENTER.
3) Write: chkdsk, and press ENTER.
(The later will take several minutes, but you can read what stage it is doing).
Apr 16, 2009 | Computers & Internet
System freezes on boot up
hi there,
did your system to press F1 to continue. not try to go on BIOS setup. on booting process press F2 or Delete tab. and then click on safe mode if the booting will continue to run. come up a confirmation if you continue in safe mode click yes. and then work on that system for a couple of minutes, and then restart you pc.
you have too many start up programs. that why it will freeze during start up.
Nov 29, 2008 | Biostar P4M890-M7 Motherboard
White Screen
Safe mode it works forever?
Try reseting your video settings.
Right click the desktop
Go to properties
Click the settings tab
Choose your optimum resolution 600x800 and 1024x768 are most common. Unless you have a wide screen.
If that doesnt help try disabling programs that start with the pc. However unlikley it may see, if everything works fine in safe mode, it must be related.
Start > Run > Msconfig
Click the start up tab.
Click "Disable All"
reboot
How does it work now?
Oct 11, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion dv6000z Notebook Logo
242 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
