Question about Dell Dimension 2400 PC Desktop
Yellow light on dell dimension 2400 and it won't work
  • 6,784 Answers
HI, this is signaling an issue that is concerning the power unit(power supply). this can also be an issue with the mother board as well. you can confirm the actual issue by, inspecting the cooling fan that is on the power unit. if the power unit fan is not running when you push the power button to power up the PC, replace the power supply. if the fan is running, replace the mother board.
Posted on Jun 21, 2009
  • 3940 Answers
SOURCE: dual monitors on my dell dimension 2400
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
Posted on May 20, 2008
ghouliass
  • 105 Answers
SOURCE: trying to get wifi for Dell Dimension 2400
Less expensive for recieving is simply the "usb stick" I would recommand a "ralink" chipset, (can be found in USROBOTICS and some less expensive brand like TOPLINK
Posted on Nov 26, 2008
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
  • 3940 Answers
SOURCE: Dell Dimension 2400 with steady amber power light
Steady amber power LED is indicative of a problem with the motherboard. Remove all external connections except power, remove all PCI Cards, ram, disconnect power from all drives, turn on see if power LED is still steady amber. If it is, more than likely the motherboard has a failure. Also check to see if the CPU heatsink is firmly seated (The plastic retainer has been known to fail causing the CPU to overheat)
Posted on Oct 04, 2009
Dell dimensions 2400 series diagnostics lights are ABC are yellow and D is off
try here
http://support.dell.com/support/edocs/SYSTEMS/dim2400/en/sm_en/advtshoo.htm
Sep 07, 2011 | Dell Dimension 2400 PC Desktop
Put in new memory in a dell 2400 now front
make sure all cables are properly seated inside the case. just the d light being yellow and no other means some other failure occured,
Feb 20, 2010 | Dell Dimension 2400 PC Desktop
My dell 2400 wont start, a yellow blincking light keep
let an expect service your machine component by component. if the problem persist check the mother board of your computer for bad components.replace board if bad. thanks
Dec 19, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 that has had a power surge
Um, unless you are happy soldering VERY finely and under pressure then go for it, but to be honest, you can pick one up for £30-£50 that will have everything you need and more!
Oct 14, 2009 | Dell Dimension 2400 PC Desktop
Unable to reboot system after upgrades
1. Check your RAM speed
2. Install the old RAm and see if the problem persists
Jun 24, 2009 | Dell Dimension 2400 PC Desktop
Computer hangs at the Dee Logo
Look at the description for the diagnostic lights on a Dell 2400 here under "A possible expansion card failure has occurred."
If you have recently installed any card (wireless, sound, etc.), then this would be my first suspect.
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Video out on dimension 2400
all of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Oct 09, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
638 people viewed this question
Alun Cox
