We had a power outage and now after power has came back on the switches keep freezing and dropping connections
SOURCE: I want reset the factory
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
SOURCE: I just had a power outage and now my HP 4104gl
I hope that you've gotten this problem resolved by now... but if you haven't, it sounds like you have a blown power supply. You can contact HP at 1-866-my-procurve. Use caution as to how you tell you it died or they won't help you with this problem.
They may be able to ship you replacement power supply or switch.
SOURCE: cannot ping hp procurve 2900 48 port switch
are you accessing this switch from the management VLAN? I believe this switch you will need to assign it in the CLI/Menu.
