Question about Fujitsu Siemens LifeBook E4010 Notebook
Notebook cannot power up
System cannot power up at all (with battery and main supply, without battery-with supply,with battery-without supply).
In some cases (1 of the 50) when WindowsXP is up system is working only for a few minutes and then turn off without any reason (not classical shut down but notebook is down in a moment).
Thanks for help,
Milan
    President:
  • 3,278 Answers
Any lights on the A/C power adapter ?? If not, then the power adapter is faulty. If the adapter is OK, the power connector on your Lifebook is faulty. Good luck
Posted on Jun 21, 2009
  • NinaE Jul 02, 2009
    Resolve your problem ?? Thanks.
In my home using 100AH battery for inverter , want to know wht happens if the baterry is not connected to inverter ? Is battery life decreases..? or WHAT ELSE WILL HAPPENS TO BATTERY ..? plz give an...
It depends upon the type of UPS.
A true UPS requires a battery to be connected to the inverter at all times. Mains power is used to charge the battery constantly and battery is required to continually supply power to the inverter which then converts the voltage to mains supply voltage.
A lower powered and cheaper type UPS areswitch-over types, when the mains supply fails, the UPS switches over to thebatteries and the inverter in milli-seconds which then supplies mains power to thecomputer and peripherals.
This type UPS may operate without a battery, but it depends upon the design of the UPS and the battery error detection system In most cases I doubt it can operate without a battery. You can try the UPS without a battery, make sure the battery terminals do not short against each other.
Dec 21, 2011 | Televison & Video
My acer aspire 6530 suddenly stopped charging the battery, it works with battery, works with battery and main power supply (yet, as long as the battery is still charged), and it certainly doesn't work with...
Seems like this is the case of a bad power supply adapter, and needs to be replaced. But to make sure we are on the right track, you mention towards the last statement, you said that when your laptop is off, and the battery is installed on, and without the power supply, the computer power button would flash and no sign of life right? Well take these step to see if it is the power supply, 1, check to see if the small green light is lighting from the powersupply adapter. If it is not, then 100% you have a bad power supply. 2, does the laptop power on when using the power adapter only, and with the battery pulled out? If not, then 85% still is your power supply and the other 15% is your power jack, either is loose, or bent, as we tend to plug in and out alot. 3, Does the laptop power on with the battery itself without the power supply adapter? If it does, it is not your battery. The reason to the laptop power light blinking with the battery installed only could be that the battery is low/drain and does not have issufiect charge to power up your laptop. And to say that when your system is on and your plug in the powersupply, and the small battery icon says it's charging but actually it is not. It could still be your powersupply, it is damaged but a smart chip installed on your powersupply only sending signal to your laptop, this chip is only to prevent the battery from over charging. So if you have another power supply, you cna test this out. But at this point, they was you described things, I believe it to be the power supply. I hope this help, if you have any question, let me know.
Jan 17, 2011 | Acer Aspire 6530-5143 Notebook PC
HP STUCK IN HIBERNATION MODE. HOW DO YOU FIX?
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
or this:
1. Remove power supply and battery.
2. Hold power button down for 30 seconds.
3. WHILE STILL HOLDING DOWN POWER BUTTON, INSERT POWER SUPPLY, THEN INSERT THE BATTERY. *THE POWER BUTTON SHOULD BE HELD, THROUGHOUT THIS ENTIRE STEP.
4. At this point, the blue light and the charging light should both come on, and the computer should start properly.
And check ur operating system for errors by downloading reginout
Aug 16, 2010 | HP Pavilion dv6000z Notebook
I have a fujitsu notebook model lbs6120-aa029e0b0. At first the notebook would start but not recognise the hard drive. when turning it on at other times it would work normally then freeze. Now the...
If the notebook is not working at all now, you have to test the power supply to see if it is providing enough power to run the system. I would try to put the battery back on, let it charge for at least 12 hours, then try to turn on the system with the battery still installed on the machine. That way we can eliminate whether the power supply has sufficient voltage carrying capacity to operate the system.
If that doesnt work, then its time to call Fujitsu.
Aug 02, 2010 | Fujitsu LifeBook E8010 Notebook
Hot laptop and battery charger
It may well be that the battery that's being charged is getting past its sell by date. They only last for so many charges. easy way to find out is remove the battery, connect the power supply, and if the charger power supply doesn't get hot (usual to get warm) then its your battery. It is perfectly okay to use the laptop without the battery installed on the mains.
Jul 15, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
No power with power supply plugged in
I would use a power supply tester to be certain. Voltage meters are a good indicator of weather or not the main power distribution points are working, but there are actually several points providing power.
If this still doesn't work, check the power at the battery terminals to see if the battery itself is getting any power sent to it.
Apr 30, 2010 | Packard Bell (190169) Power Supply
Compaq-50 preserio Cq50will not turn on
Try another power supply. Try it without the mains connected and with out the battery. If they both fail you will need to replace the system board.
Feb 24, 2010 | HP Compaq Presario CQ50-130US Notebook
Laptop model ze2000 dead set
remove the hard disk and the ramm and try to switch it in without battery just conncet the main power.
Dec 10, 2009 | HP Pavilion ze2000 Notebook
Battery will not charge
remove battery and try on mains power.
Aug 09, 2008 | Acer Aspire 3050-1733 Notebook
Acer notebook screen will not energize?
Hi, If you keep you battery for a long periode of time without using it it may damage and damage you system too. Remove the battery and check weather any junks are there on battery connector. if it is there clean it and try to boot without battery and check. thanks arun
Aug 12, 2007 | Acer (91.AD303.001)
Fujitsu Siemens LifeBook E4010 Notebook Logo
552 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
