Question about Epson Stylus CX5000 InkJet Photo Printer
Epson cx5000 leaves gaps in the test page lines. If it were a Canon I'd say the print heads need cleaning. How do you clean the print heads on an Epson cx5000
  • 93 Answers
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
I have an Epson NX400 printer but the yellow and black ink test pages are showing gaps and missing lines. I replaced both ink cartidges twice and did the head cleaning and nozzle check but nothing seems to...
Try to print something that is pure yellow and pure black. Set it to BEST PHOTO. If you see gaps or missing lines, your print head could be clogged. You will need to use a cleaning solution to remove the clog.
Jan 16, 2010 | Epson Stylus NX400 InkJet Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
Cleaning the Print Head 21
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
INK DOES NOT FLOW. HOW TO CLEAN INK AREA.
Here is a few steps to clean the print head of your printer.
1. Make sure the CX5000 Series all-in-one is turned on but not printing, and the ink cartridges are not low or expended.
2. Right-click the printer icon on your taskbar (in the lower right corner of your screen). Select Head Cleaning.
3. Click Start or Next.
Cleaning takes several seconds. The CX5000 Series runs a head cleaning cycle and the On light flashes.
Caution:
Never turn off the CX5000 Series while head cleaning is in progress. You may damage it.
4. When the On light stops flashing, make sure paper is loaded in the CX5000 Series, then do the following:
Windows:
Click Print Nozzle Check Pattern. Then click Print.
5. If there are no gaps or lines, click Finish.
If there are still gaps or lines, or the test patterns are faint, click Clean to clean the print head again.
If you don’t see any improvement after cleaning three times, refer to Problems and Solutions. You can also turn the printer off and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
Tip:
If you do not use your CX5000 Series often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Hope this initial / info idea helps.
Dec 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
When I print/copy it is missing lines of ink and not getting the whole image. I replaced the ink and have cleaned the head
Sometimes it requires several head cleaning passes to fix missing lines. Make sure the test pattern after cleaning has no gaps. Print the test page. If test page is bad and you have replaced all ink cartridges, then junk the printer or call Epson for a replacement. Even if out of warranty, the may give you a great deal.
Sep 30, 2009 | Epson CX8400 All-In-One InkJet Printer
I have replaced my cartridges, how do I perform a nozzle check
Download the user guide from epson:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=72185&infoType=Overview
To do a print head clean do this:
Firstly note that this won't work if you have any error lights on.
Turn on the printer.
Press the Setup Mode (screwdriver) button to enter the Setup Mode.
Press the A (top left of the LCD Screen) or one of the Arrow buttons repeatedly until "Head Cleaning" (or Nozzle Check)
appears on the LCD screen, and then press the Color button.
Cleaning of the print head starts and "Head cleaning" appears on the LCD screen. After each clean
perform a nozzle check to confirm that the head is clean and to reset the cleaning cycle.
Note:
If the print quality has not improved after repeating this procedure four or five times, turn this
product off and leave it alone overnight. Then repeat head cleaning and nozzle checks if necessary.
If the print quality still has not improved, you may need a third party head cleaning fluid, just try googling for "inkjet head cleaning fluid".
To maintain the print quality, you should print a few pages at least once a month.
Please take a moment to rate this solution. Thanks.
Mar 23, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Black ink not printing
You have to run a head cleaning cycle:
Follow these steps to clean the print head:
  1. Make sure the Stylus CX is on and the cp_light_183_er.gif ink light is off.
  2. Hold down the cp_button_48_er.gif ink button for 3 seconds until the cp_light_1.gif On light starts flashing. The Stylus CX runs a head cleaning cycle and the cp_light_1.gif On light flashes.
    alert_caution.gif Caution: Never turn off the Stylus CX while head cleaning is in progress. You may damage it.
  3. When the cp_light_1.gif On light stops flashing, turn off the Stylus CX.
  4. Load letter-size paper in the sheet feeder.
  5. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds. The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like:
    Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
  6. Examine the nozzle check. If it does not look like the nozzle check pattern with no gaps as shown above, repeat steps 2 through 6.
alert_note.gif Note: If you don't see any improvement after cleaning the print head three times, turn off the Stylus CX and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
If you do not use your Stylus CX often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Oct 24, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
344 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
