Question about OfficeMax 0M96431 Shredder
The blue light stays on when the bin is not full & the door is closed
  • 1 more comment
  • alsmith39 Jun 21, 2009
    The Blue light stays on when the basket is empty and the door is closed, it was unplugged overnight, we paid more for this home shredder but it seems no better than the cheap ones!!
    how do we remove the top, we've tried with no success
  • 15,935 Answers
Check the optical sensor in the paper slot. It is probably covered in paper dust.
Take the top off and blow it down with compressed air (not canned air) you need some pressure behind it to get all the loose bits out.
Thanks for using FixYa!1
Posted on Jun 21, 2009
  • blueextc3221
    blueextc3221 Jun 21, 2009
    sorry - your top does not remove like other shredders.
    Remove the peper/basket and use the air to blow out the gears and sensors.
    THanks
    Sergeant:
  • 326 Answers
Www.electronicspoint.com/paper-shredder-troubleshooting-t54016.html
  • 749 Answers
Try to reset it unplug it for 30mins and try again.
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
Full bin-door open light on with empty closed bin
Pull the bin out and look inside for a push switch that the bin pushes against. See if it moves freely. Likewise it may have an LED switch, see if it's blocked.
Oct 09, 2014 | Office Equipment & Supplies
Bin full door open
I found the nylon "bin full" flapper in the center of the head of the shredder is supposed to trip a microswitch indicating bin full. I removed the flapper and tapped on the switch. It came loose with a puff of paper dust. I replaced the flapper and it's back to good as new. Seems the dust built up around the switch and it was stuck.
Mar 31, 2014 | OfficeMax 10-Sheet Micro-Cut Shredder...
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
96ChryslerCirrus: 'door' warning vs odometer miles, Dome light stays on.
In the Ford Ranger, the light switch can be found in the door, right by the latch. You may need to use some WD-40 to get to work properly. -------------------------------------------------------------------------------------
zed bull
Nov 28, 2012 | 1996 Chrysler Cirrus
Doors are closed on my 1997 expedition but door ajar light stays on
It sounds like one of the door switches isn't working properly or not being pressed full in. Is the interior light on.
Feb 06, 2011 | 1997 Ford Expedition
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
The status light is red, what do I do?
Check the following: Are ink bottles installed correctly. Are all doors closed properly, Check paper is not jammed. Is the dust collector unit full, its next to the blue ink, pull out and shake over bin. I have had a 300 for 3 years and my red light has come on, I did all the above and am off to buy a CLP 315, Harvy Norman $198. Good luck.
Jan 31, 2010 | Samsung CLP 300 Laser Printer
Door ajar light & washer fluid light & bell dings,
sound like your fluid sensor may be stuck or bad if light stays on try tapping the washer motor on the resevoir if it goes out faulty sensor as for the door ajar light it might have bad connection with sensor saying the door is closed local dealer should be able to troubleshoot sensor
Aug 23, 2009 | 2003 Ford Expedition
Ice maker not working
Press and hold the flapper in dont block the optics there is a light beam that goes across and you will see a u shaped notch in your ice bin on the door this determins when the bin is full when the beam is blocked it thinks the bin is full ..After pressing and holding the flapper in what does the red light do keep blinking ?? if so how many time before there is a pause and repetes if it stays on solid i need to know that too
Jan 28, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
OfficeMax 0M96431 Shredder Logo
90 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Randy Schumann
Randy Schumann
Tom Chichester
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
