Question about Bosch Dishwashers
My Bosch SHU43C will sometimes make a loud noise
My Bosch SHU43C dishwasher will sometimes make a loud noise while the dishwasher is running. When this happens I open the dishwasher door and restart it and the noise stops. What is happening? Is it expensive to repair? Should I just replace the dishwasher?
  • 6,784 Answers
It may be more cost affective to just replace this unit. the circulation motors that are used in these dishwashers are not reliable. the wash impellers seems to have issues dealing with staying attached to the drive stud and shaft. this will cause the impeller ti shift inside the housing, causing noise and jams.
A new circulating impeller kit will cost about 100 dollars and, labor for this type of repair is 80 dollars an hour.
Posted on Jun 21, 2009
Our Bosch SHU43C Built-in Dishwasher sticks in the drying cycle.
I have the same dishwasher and started experiencing the same problem last week. It is now fixed (at least for the moment). Here's what I did first. I checked the drain pan under the machine for water(none), the heater for continuity(okay), the float for binding(none), and the float switch for proper functioning(okay). I tried turning the ckt breaker off for a couple of hours to see if that would reset the control module(no effect). I then dissasembled the front door and removed the control module. I had previously read about the common problem of a cold solder joint on the heater relay pin on the control board. My heater was working and the joint looked good but I resoldered it anyway. I reassembled everything and it worked perfectly! My conclusion is that it was either a cold solder joint that was somehow causing the problem or a connector issue that got resolved during my disassembly/reassembly. Hope this helps.
Dec 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh shu43c never stops running.
If you have a Bosch shu4300...check this site.
http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/
My issue was a heater fault and fixed the problem by resoldering a bad joint. Works fine once this was fixed.
Nov 24, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Shu43c Drain pump is very loud! This's supposed to be a quiet one
Drain pumps are relativley cheaply manufactured with basic technology, we can not even determine which way they spin, if something got into the pump it could be creating the noise, otherwise it could be the pump itself which will detereate over time, also if these run dry they seam to make more noise.
Nov 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43c Dishwasher
go to the bosch site and click on Service. It takes you to the parts where it describes all the parts and numbers
Aug 03, 2008 | Bosch SHU43C05 Stainless Steel Built-in...
Bosch SHU43C
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
765 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
