Question about Maxtor MaXLine Pro 500 500GB 7200rpm 300MBps Serial ATA II Serial ATA/300 Internal (7H500F0FT) Hard Drive
I am trying to install a Maxtor Basics 500GB External Desktop Hard Drive and cannot see the drive on my PC. I'm assuming it is not installed. I operate a Windowss XP Platform. Help!
  • 27 Answers
Right click on my computer and go to manage, then go to storage, disk manager and see if the disk shows up there, you may need to partition it first, you can make one partition of that hard drive. If it is not in there, check the jumpers and make sure it is not the same as the main HD. The main drive should be master and the second drive should be slave, or make it cable select and do it in the bios.
Posted on Jun 21, 2009
Maxtor 3200 hard drive not working alongside Maxtor Basics
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 21, 2009 | Maxtor Hard Drive
Open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Computers & Internet
How can I open the Maxtor Basics 500GB case??
See this link:
Mar 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
External Maxtor Basics 1Tb XP/Vista
its the drivers not installed on vista.. ur drive is fine
Mar 14, 2009 | Maxtor Hard Drive
Installing the external drive
In XP and Vista no need to install.
They will detect automatically.
To know, goto Windows explorer.
Find drive letter other than your local drive.
Usually called "removable disk".
Dec 26, 2008 | Maxtor OneTouch II external hard drive...
I brought a Maxtor basics external desktop hard drive, 500gb for my laptop. my laptop is windows vista and i can't get the portable hard drive to work or install onto my laptop. what can i do?
A few basics.. are you sure you've hooked it up right? meaning usb cable plugged into both the laptop and the hard drive? Does that particular model hardrive require a power pack to operate? If so, is that plugged in and operational? Assuming that is all OK.. does your system recognise that new hardware has been added when you turn it ( the hard drive on) and it is plugged in? It should but if not.. you may have to use the control panel and choose the ADD NEW HARDWARE feature.. At some point during all this. your system shoud acknowledge that new hardware has been recognized and it should ask for a cd with drivers on it to be installed or it may already have drivers that are compatible with it and self load.. If you fail to get any kind of new hardware acknowledgement, you may have a bad USB cable, a bad USB port or your new hard drive is not operating correctly.. I'll check back periodiaclly to see if any of these suggestions got you going or if you need any more help.. Good luck
Sep 23, 2008 | Computers & Internet
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
Computers & Internet Logo
223 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
