Question about Bialetti Mukka Express
My bialette does not boil all the water to the top!!!!!
I've changed the gasket multiple times, but only sometimes has the bialetti made a full chamber of coffee without hardly any water in the bottom chamber. I use a steady heat of medium high. I've tried different coarsenessess of coffee. Sometimes it works well, but most times, I hardly get any coffee from it, with half the water staying in the bottom. It took 20 minutes for only a small amount of coffee to boil to the top. I also thoroughly clean all the parts after I use it. I know another person who has this same problem. I've asked the coffee place where I had bought it, and they told me to clean the stem of the strainer and I did, but no change
    President:
  • 3,433 Answers
Put some vineger in it and heat it up, like a flushing and then rinse out thoroughly. See what that does for you.
Posted on Jun 21, 2009
I have changed the rubber seal and now I get no coffee!!
check under that plate with holes and make sure water is just under safety valve inside. make sure plate holes are open and the pipe that delivers the coffee
Sep 01, 2013 | Bialetti Moka Express 6-Cup Coffee Maker
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine,...
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
Apr 19, 2011 | Bialetti 4cup Stainless Steel Espresso...
Hello! I change the rubber sealer to my Bialetti 12 cup yesterday and since then the water stays in the bottom and does not rise to the top. The sealer is properly put in. I have not done anything...
This happened to me, too....the gasket needs to be broken in so that it seals properly, which will happen once it's been used several times. In the meantime, just tighten the pot together extra tight and that will help to seal the gasket properly. After several uses, you won't have to tighten it so much and can go back to how you've always done it. I hope this helps!!
May 19, 2010 | Bialetti Moka Express 6-Cup Coffee Maker
Hello I've had my stove top Bialetti for many years, and its worked beautifully. However, recently I've had a lot of problems with it. It is taking much longer for the coffee to brew, and in fact it does...
I do not supect the basket just make sure it is not blocked with limescale or other debris as this will reduce the flow of steam through your coffee grounds.
if this is ok then check the pressure release valve on the lower chamber it may be open or defective see if steam is coming out of it when your use your machine if you do not get pressure in your lower chamber it can not lift all the water to the top.
i do not know if the pressure release valve is a replaceable part.
Nov 13, 2009 | Bialetti 20-9 Stove Top Espresso Machine
Barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Jun 28, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Jan 06, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
Feb 20, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Bialetti Mukka Express Logo
535 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
