Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
I have to hold my Ipod forward in the dock to get sound
I have tried various ipods with their correct adapter and the same problem. Mine is less than a month old. It seems the Bose recptacle is weak. I am taking mine back. I might try another one but sound like this is a design issue.
    Sniper:
  • 71 Answers
Not a design issue as far as I've heard. They made the 30-pin din connector a bit 'soft fitting' so that it won't break from pulling out an iPod hundreds of times. The SoundDock II and SoundDock Portable are actually some of the more durable iPod products I've ever seen. The original SD also, but that had a weak power supply. I wouldn't worry about this happening again.
Posted on Jun 21, 2009
Bose troubleshooting
Sounds like it's either a problem with the connector on the iPod or on the dock. To find our which see if it works okay on another dock - if you know anybody with one our text it on a demo model in a store. Or it could also be the plastic dock adapter - take our the adapter and try docking without the adapter.
Jun 20, 2014 | Bose SoundDock digital music system...
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
Onkyo RC-729E remote for a DS-A3 iPod docking station. The remote seemed to work sometimes when I first got it. Few days later it does not work at all. Have tried changing batteries. Any other things...
The issue turned out to be that the iPod was not seated in the dock correctly. The adjustable back was adjusted too far forward so it was docked improperly. Correcting this corrected the remote issues. Everything works great now.
Jan 03, 2010 | Onkyo Televison & Video
I cant get any sound when i plug in the 8GB iTouch
Chances are it's the docking module... try pulling the ipod forward and see if you get some sound.
One can slip something in behind the ipod to prop it so it will give sound sometimes but overtime the problem gets worse in my experience.
There's the Auxillary input as well in the back... i.e. running an adapter from the headphone jack to the back. For an Ipod Classic one can leave it in the docking station re-charging - for the nano, with the headphone jack on the bottom it can't be placed in the docking station (though can be - recharged when not plugged in)
Don't forget to switch the selection to Auxiliary rather than Ipod
That being said, in terms of sound quality, the quality is much better (highs are higher) when plugged into the docking station compared to the Auxiliary input
Oct 22, 2009 | Altec Lansing Inmotion-IM600...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Bose Portable sound dock remote not working with iPod Classic
I have the same problem with mine. Called Bose Belgium and waiting for answer but it seems there's nothing to do.
Wait and see
Sep 21, 2009 | Bose SoundDock Digital Music System for...
Keeps freezing on me, especially when I forward to
Your best bet would be to do a soft reset of the ipod:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If this does not work then you may have to re-format the ipod in itunes. If you click on the ipod in itunes you should see a RESTORE option on the main page.
Jun 24, 2009 | Apple iPod Photo MP3 Player
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Harman Kardon Go + Play Portable Speaker Keeps Shutting Off
I just had this exact problem. I'm using an ipod mini. I solved it by docking the ipod firmly at the angle
the dock is at and have the ipod at an angle, not flat. I put the plastic and rubber adapter for the mini as instructed and also placed the rubber adapter for the nano upside down to keep
the ipod propped at an angle. (Also can use something similar to keep ipod propped up at an angle)
Took a while when I first used to figure out how the dock worked. The dock is a little weird how it is hinged to go from an angle to flat. Nothing in the instructions about this. By putting the ipod flat it would still have a connection to charge and play but the power shuts off every 10 minutes. I spent a whole night having it shut off every 10 minutes. This drives me crazy when systems have features like that which always seems to cause more problems (just my humble opinion)
By having the ipod at an angle I'm currently just now having it run an hour and 20 minutes and counting with no shut offs,(fingers crossed) but so far so good.
Saw on the internet that if the ipod is not connected firmly the system has an auto shut down. I think the ipod's weight propped at an angle keeps the connection firm. Also some said they want to see the ipod display, there you go!!!! This seems to be working so far for me, may be worth a try...I was about to return mine but I love the sound so I'm keeping mine now!!!! Works fine. Happy camper again.
Please reply if this works for anyone it worked for me.
Jun 30, 2008 | Harman Kardon Go + Play Portable Speaker...
Ipod Nano Second Generation
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
402 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
