I hooked up my stereo amp to my external speakers that were also still hooked up to my tv. now I don't get any audio from my tv just a high pitch sound. Is this an easy fix?
  • 10,865 Answers
Hi, I can help. It sounds like the TV internal speakers were turned off so that the only speakers to have sound were the external ones. Go to your menu and find the sound area. There you can tell the TV to send sound to the internal speakers once again and not to external.
Posted on Jun 21, 2009
RCA P52940 question sound
check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
May 12, 2016 | Televison & Video
How do i get the external audio output to work?
First make sure that your TV has an audio OUT. Most do not. If you do then you can plug into that but you will have to go into the menu on the TV under audio and turn on the external speaker feature. If you do not have an audio OUT then you will have to hook you speaker to the audio OUT of your home stereo system and hook the source output to the input of your stereo. Source being (dvd, cable box). In that case you need to turn off the internal speakers on the TV and just run it through your home stereo system.
Mar 07, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
I have a sony smary tv and when I start a movie the viedo is good but there is no audio what am I missing
The first thing I would do if there is any other way to check audio like head phones or aux out to stereo try, this may tell if you have a bad audio chord, not sure exactly how your set up is but a bad chord our improper jack connection might be the answear, good luck ! Bret
Mar 08, 2015 | Sony BRAVIA KDL60EX720 60 Inch 3D 1080p...
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
Gerard
May 13, 2010 | Pyle PT-2000 Amplifier
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
Hooking up external speaskers to my Panasonic TV
you will need to buy a surround sound receiver. the new tv's do not have an external speaker jacks on them. you might also try a old stereo receiver hooked up to the tv's audio out jacks
Jan 24, 2009 | Panasonic 50" 720p Flat-Panel Plasma HDTV
Bose 151 main with amp
Does your tv have stereo outputs? if yes all you have to do is run RCA red..white jacks into tv outtput then run the other ends into the amps tape or aux or cd input and your done! If you dont have outputs on tour tv you will have to but an RF converter box (about 20.00 at wal-mart) and hook that into the tv and the cables will run out of that to the stereo!
Jan 14, 2009 | Bose 901 VI Main / Stereo Speaker
Can I hook my TV directly up to Bose 201 speakers?
It depends on the TV audio output connections. Most TVs have low level audio outputs (RCA Jacks) that require a amp but some do have external speaker connections. You will have to refer to your manual or check the back of the set.
Nov 25, 2008 | Audio Players & Recorders
No Audio Out to Stereo Reciever
First have you went in menu and check audio to see if you are on the variable audio or external output? Check to see if this makes a different with audio jack hookedup correctly of course!
Sep 11, 2007 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
