Question about Milwaukee Tool 10" Magnum Compound Miter Saw
Motor on miter saw is runnig back wards
I have a milwaukee magnum 4800 rpm 15 amp. 10" blade
replaced blade because it was not cutting put new blade in still not cutting then i noticed blade was running back wards. Put blade in where teeth are pointing out cuts great but all the saw dust comes out in your face
jerry
  • 1 more comment
  • masterj45 Jun 21, 2009
    The cat#6490 ser.#799a493450639 The saw is at less 20 yr old I don't use it all the time I just use it for my jobs around the house.I have need messed with the motor actully this was the first I changed the blade. because it wasn,t cutting. Thats when I noticed it was running back wards. If I put the blade in back wards it cuts great
    jerry
  • David Ford
    David Ford May 11, 2010
    Is this a newer saw? Have you done any electrical work to it? I haven't heard of a saw doing this in a long time. Give me the exact model number and I will find a wiring schematic for it. It is possible that some wires on the switch are reversed and or the field is in 180 deg out. Let me know
  • Anonymous Mar 20, 2014
    Cannot lift saw blade so i can cut with it
  • 2,176 Answers
I would suggest going to Milwaukeetool.com and typing in your model number and pulling up a wiring schematic for this tool. If your switch and field are not as shown on this breakdown (its a good one) I would either take it to a repair center or change what is wrong one wire at a time. They also have a toll free number and would be more than willing to help with your problem. Let me know and have a good day. P.S. I would not run the blade backwards though.
Posted on Jun 22, 2009
The blade brake is not working on my miter saw.
Clean your saw ! Use your air compressor with an attachment to get back in the nooks & crannies, blowing all the caked up sawdust out.
Oct 09, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
May 10, 2014 | Milwaukee Tool 10" Magnum Compound Miter...
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Jammed my 6230 bandsaw during a cut and now it won't start. Are their fuses I can replace?
Go to Milwaukee Tool website and try to check if you can download a manual or electrical diagram there. You can call or email them. Check the motor capacitor.
Are you using an old or new band saw blade? If it's old/dull, try different blade. If it's new, the weld might be really bad. Old Blade and Bad weld can cause the blade to jump off. I purchased band saw blades on www.sawblade.com . Great quality blades; they have porta band blades. Call them.
Oct 23, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
I want to know the steps needed to replace a 1/2" keyed chuck.on a Milwaukee 0234-6 Magnum Drill
they make a service fixture for that BUT if you can find a thin wall open end wrench that will fit behind the chuck on the hex of the spindle you can still do it. What you will need to do is remove the left hand chuck retaining screw, put the wrench or similar item over the hex and then put the chuck key in a hole that is about a 30 degree so that you can strike it counter clockwise to remove. That chuck is on tight and there no easy way to remove it like you can do on cordless items.
Jul 31, 2011 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
Blade stops in middle of cut, slipping motor rpm is un changed. 10" compound sliding Bosch miter saw
Going on the information aas I read it, the blade is slipping, meaning that it is not tightened enough or a spacer in the hole in the blade is too thick. Make sure that the wall plug is pulled out before attempting any work on the blade.
Jan 16, 2011 | Bosch 10" Slide Miter Saw
How do I adjust the saw to get a 90 degree cut?
if this is a Milwaukee product, go to their website at Milwaukeetool.com and you can download an owners manual that has detailed instructions on how to align blade.
May 22, 2010 | Milwaukee Tool 10" Magnum Compound Miter...
Tripping 20 amp breaker
when things start overheating componants start to break down. sounds like you need to check the armature and field for burnt areas. at least change the brushes. were you bearing down hard? sounds like the motor may not be enough to cut quickly, maybe more slowly. hope this helps
May 07, 2010 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Milwaukee Tool 10" Magnum Compound Miter Saw Logo
201 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Dave
Level 1 Expert
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
