Question about HP OfficeJet 6210 All-In-One InkJet Printer
After down loading the driver / software for HP OJ 2610, the install stops at 5% @ "installing step 3/4". I have tried this 3 times - same problem.
Do not install the s/w first.connect the USB cable,allow the drivers to install and then it would prompt you for the cd.insert it then.If still it does nit work,copy the contents of the cd on a local hard drive and then browse for tht location when the computer prompts for the software.
Posted on Jun 21, 2009
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
How can i have hp psc 1510 driver and valid Win32
Here's the fix:
* First uninstall your current HP installation.*
Step one: Uninstall the printer driver and software
1.
Disconnect the universal serial bus (USB) cable from the computer.
2.
Insert the printer software CD into the computer.
3.
A prompt to uninstall the software displays. Follow the on-screen instructions to uninstall the software.
4.
Restart the computer.
Step two: Turn off the Terminate and Stay Resident (TSR) programs and other background programs
When the computer is turned on, a software group called the Terminate and Stay Resident (TSR) programs automatically loads. These programs activate some of the computer utilities such as the anti-virus software but are not required for the computer to function. Occasionally, TSRs prevent the printer software from loading so that it does not install properly.
In Microsoft Windows 98, Windows ME, and Windows XP, use the MSCONFIG utility to prevent TSR programs and services from starting up.
1. Click Start and then click Run. The Run window opens.
2. In the Open: box, type msconfig, and then click OK. The MSCONFIG utility window opens.
3. Click the General tab.
4. Select Selective Startup.
5. If there is a check mark next to Load Startup items, click the check mark to remove it.
6. For Windows XP systems only - Click the Services tab and place a check mark in the Hide All Microsoft Services box. Select Disable All.
7. Click Apply and then click Close.
8. Click Restart to restart the computer.
Unplug your USB printer cable and reinstall. That's it!
Visit the HP Help Documentation Page for this error.
Here's the text from their page in case the URL for this changes:
Issue
The printer software installation stops and the Printer Driver Unknown error message displays on the computer. This document applies only to products connected with a USB cable.
Figure 1: Printer Driver Unknown error message
Solution: Follow the steps below to resolve this issue.
NOTE: These instructions do not apply to Windows 2000 because the MSCONFIG utility used in Step two does not exist in Windows 2000.
1.
2.
3.
4.
NOTE: This step does not apply to Windows 2000 because the MSCONFIG utility does not exist in Windows 2000.
1.
2.
3.
4.
5.
6.
7.
8.
Step three: Install the product software
Listed below are several options for installing the product software. If the product software CD is not available, HP recommends downloading and installing the product software from the HP Website at www.hp.com.
Method one: Install the product software from the CD
1.
If the product software CD is still in the computer CD drive, remove it and re-insert it in the CD drive.
2.
If the software installation does not start automatically, follow the steps below.
1.
2.
In the Open: box, type D:\setup.exe, where D is the letter of the CD-ROM drive.
Follow the on-screen instructions to complete the software installation.
Method two: Download the software from hp.com
1.
Go to www.hp.com and click Software and driver downloads.
2.
Type the model number of your product in the Search box.
3.
Select the operating system of the computer to which the device is connected.
4.
Click the downloaded software to start the software installer.
5.
Follow the on-screen instructions to install the software.
Step four: Use the MSCONFIG utility to enable the Startup software
1.
2.
In the Open: box, type MSCONFIG and then click OK to start the MSCONFIG utility.
3.
On the General tab, select Normal Startup to automatically enable all features the next time the computer is started. In Windows XP, click the Services tab and select Enable All.
4.
5.
Click Restart to apply the changes to the computer.
Jan 20, 2015 | HP Computers & Internet
I do not have an installer for my HP Photosmart 2610
you can download the driver from hp website. Just follow the steps in downloading the driver
1. go to www.support.hp.com 2. enter your product number which is (photosmart 2610) 3. choose HP photosmart 2610 all-in-one 4. click software and driver downloads 5. choose your operating system and click next = to know your operating system just click start then right click my computer or computer then click properties 6. click driver - product installation software 7. click HP officejet and photosmart full feature software and drivers 8. click download then run
May 16, 2011 | HP Photosmart 2610 All-In-One InkJet...
Hi, My MIL has this Hp Photo 2610 all in one printer and I've loaded the "driver" and bought a new cord but the computer still dosen't work...what now?
Did you install the full feature driver or just the basic driver ?
Do you have another printer installed. If so, select the Photosmart 2610 as your default printer.
There's a support page for drivers and software, including updates.
Support for the Photosmart 2610:
http://h10025.www1.hp.com/ewfrf/wc/product?product=421139&lc=en&cc=us&dlc=en&lang=en&cc=us
When needing more help, just add a comment.
Apr 15, 2010 | HP Photosmart 2610 All-In-One InkJet...
Software won't fully install
Solution one: Run the Access Denied utility A utility is available that addresses access denied errors. This can be helpful for the 2203 error.
  1. Go to the HP Web site (www.hp.com) and in the search box, type AccessDeniedUtility .
  2. At this link:
  3. http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=oj-24444-2&cc=us&lc=en&dlc=en
  4. Click the Resolves "Access is denied" error during software installation link.
  5. Download and run the utility following the onscreen instructions.
  6. Re-install the software.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next solution.
Solution two: Re-register MSIexec service
  1. Click Start , then Run . The Run window opens.
  2. In the Open: line, type Msiexec /unregister .
  3. Click OK .
  4. Click Start , then Run . The Run window opens again.
  5. In the Open: line, type Msiexec /regserver .
  6. Click OK .
  7. Re-install the software.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 06, 2009 | HP Photosmart 2610 All-In-One InkJet...
Photo smart 2610 all in one scanner will not scan
hey i also had this type of problem. but i solved it and hope it will solve yours too.
first of all uninstall all ur hp drivers and softwares related to the hp printer. then restart your pc. now disconnect ur printer with ur computer and turn it off and again on after 15 secs.
now insert the cd which i have got with the hp printer in the cd-driver of ur pc and install the driver.
after the installation is complete, connect ur printer, but do not remove ur cd.
then start scanning, and if it will again ask for installing driver, u dont have to worry it will install it from the cd.
this would surely help u, if problem persists, please tell me.
Jan 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Scanner
try disconnecting the printer, uninstalling the software via Add/Remove Programs[remove all HP OJ 6110 and old HP driver installs], Shutdown and restart, leave printer disconnected, then try installing the software again but wait for the installation software when to tell you to connect the printer.
Try this link if you do not have the software handy,
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=oj+6110&submit.x=0&submit.y=0
Check the label on the back/bottom of the printer for the exact sub-model to match with correct driver.
Oct 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OJ 7410 printer disappeared
Nothing to worry about. Go to HP.com and from there select Software and Driver Downloads. Download the Full feature software and driver for windows Vista. Run the Installation.
If the softwares are installed it will ask you to "Add a device". Add a device and select network option. The device will be installed. Now there is a patch on HP.com for unexpected uninstallation. Download it and install it on the computer. It will resolved the issue.
Feb 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hepl me find and download a driver
if u dont have the software, please download from the link ftp://ftp.hp.com/pub/softlib/software7/COL15106/oj-40457-1/CDA_DriverOnly_NonNetwork_enu.exe
and install... simply click next button.. switch on the printer only when they ask at the time of installation. and simply click finish button. its over.
Dec 08, 2007 | HP Deskjet F335 All-In-One InkJet Printer
HP software will not install
this error tell us that you are not logged in with full admin rights on your computer to install software and driver package, and it also sounds like you are trying to start software install using the "run command"
There is nothing wrong with printer but you do seem to be having trouble loading the required software and driver package on your p.c.
Are you also using new Vista software/driver package for your HP OJ 4215 cause the one that came with it maybe XP.
Go to HP and download correct package, AND log on as administrator with FULL priveledges, your username (normal login) may not, from the looks of this.
link to hp software download for HP OJ 4215
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=351106&lang=en&
"it obviously needs a fix--tell me what it is"
Nov 05, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
