Question about Tascam 2488 Portastudio Multitrack Recorder System
TASCAM 2488neo- Cannot play CD-R or CD-RW on a separate CD player
I have recorded plenty of songs, mixed them down, and written them to CD-R and CD-RW discs. The problem is that I cannot pay these discs on any CD players that I have. They play on the 2488 but not on any of my CD players. Should this be? The store tech where I bought it from stated that it should not be a problem to take a disc straight from the 2488 to a regular CD player.
    Problem Solver:
  • 15 Answers
Read page 75 of the Neo manual VERY CAREFULLY.
I am quite sure you will find a solution to your problem there as I had the same thing happen to me once early on.
Hope this helps.
Posted on Sep 08, 2010
  • bamacabin1 Feb 06, 2011
    Don't ignore the "finalizing" step
How to download from the Tascam 788 to the CD Burner?
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 8
Feb 04, 2011 | Tascam 2488 Portastudio Multitrack...
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
How to load music to a tascam 2488neo
I think if you had the manual you would know the answer.
Jan 11, 2011 | Tascam 2488mkii 24 Track Recording...
I want to buy a Tescam 2488neo. But i got a question before I buy it. Question- Can I record songs or musics multi-times? I mean, record acoustic Guitar first, and then record ...
Here is a link for you to look at:http://www.tascam.com/products/2488mkii.html Look under resources to download the manual or a Beginners Guide to Recording.
Aug 28, 2010 | Tascam 2488mkii 24 Track Recording...
Will not play a Memorex cd-rw
try again! burn an audio cd, but burn it at max 12x speed!!
Oct 28, 2009 | Tascam CD-RW4U CD Recorder
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Oct 20, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
179 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
